Question about Empire Comfort Systems E.F. Johnson BP196, FALCON 7500, FALCON 7510, FALCON 7514, FALCON 7540, FALCON 7544, Icom BP196, ICF3, ICF4, ICT2A replacement battery BNH-BP196
Wiring diagram for ford ef falcon
Need to know where the brown wire goes also the blue with red strip and green with yellow stripe from an old ford wiring harness ef falcon to a new pioneer unit
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Kelly,
You've posted on the wrong forum, you need to post your query in the Cars & Trucks forum.
Cheers,
Peter
Posted on Mar 06, 2013
What are the fuel injector wire colors for a ford escape 2008 3.0L v6 4wheel drive?
Okay, you know each injector has a power wire, and a ground wire that goes into the pcm? All of the power wires to all six injectors is a green wire with a red stripe.
The ground wire colors are as follows:
inj 1: green wire/blue stripe.
Inj 2: gray wire/yellow stripe
Inj 3: violet wire/gray stripe
Inj 4: yellow wire/orange stripe
Inj 5: brown wire
Inj 6: green wire/white stripe
I should note that the wiring diagram I am looking at shows this diagram as from a 2008 model manufactured during 2nd quarter of the year 2008. If your injector wire colors are different than as listed above, there may have been production changes during the year. But the power wires to all six injectors would still have the same color wire. You could figure it out that way: in other words, looking at the injector harness, same wire color to all six is the power wire, all the odd colors are the ground wire for that injector. Hope this makes sense to you. Good luck.
Feb 03, 2015 | Ford Cars & Trucks
Does anyone know which colour does what for a madza demio stereo wiring harness
It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
Sep 06, 2014 | Cars & Trucks
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
The brake light on the dash wont go off brakes are good rotors are good not the emergency brake. i have a 98 durango
check the brake fluid level and check the park brake switch it may be stuck on or out of adjustment
Apr 16, 2010 | 1998 Dodge Durango
I have a fairly old panasonic car stereo/cd changer. i just need the wiring diagram for it. what color equals what? i typed in the model number but nothing turns up. . . i had to replace the old system,...
Here is the Colors of the Cars factory harness
Constant 12V+ Red Switched 12V+ Red/White Ground Black Illumination n/a Dimmer Orange/White Antenna Trigger Yellow Antenna Right Front Front Speakers 3 1/2" Dash Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
And Here is the Chart for the radios wiring
Red 12V+ Switched power
Grey Right front speaker +
Grey with black stripe right front-
White left front +
white with black stripe l/f -
Purple R/R +
Purple with black stripe R/R -
Green l/r +
green with stripe l/r -
Black ground
orange illumination
yellow constant power
Apr 07, 2010 | Car Audio & Video
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Empire Comfort Systems E.F. Johnson BP196, FALCON 7500, FALCON 7510, FALCON 7514, FALCON 7540, FALCON 7544, Icom BP196, ICF3, ICF4, ICT2A replacement battery BNH-BP196 Logo
627 people viewed this question
Top Empire Comfort Systems Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Empire Comfort Systems Radio Communication Expert? Answer questions, earn points and help others
