Question about Garden
Lawn mower will not move
I have 12hp 5 speed troy built lawnmower working just in fall Tried to mow lawn today will not move any gears?
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello! Is The Belt Still On.Did The Little Animals Eat The Belt.Did You Check Transmisson Fluid.Did A Pulley Brake Loose.These Things Will Cause Problems.Good Luck;
SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Posted on Sep 01, 2008
lonewolf1996
  • 142 Answers
SOURCE: I have a Troy built front wheel drive mower made
It sounds like you need a new belt for the front wheels.
Posted on Jul 31, 2009
SOURCE: My lawnmower won't start
my lawn mower has a new battery but will not start
Posted on Nov 02, 2009
RonInFla
  • 86 Answers
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Posted on Apr 18, 2010
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
Posted on May 30, 2010
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-built gtx2654 lawnmower with a Birggs & Stratton engine mod 47777 typ.0229E1 want to troubleshoot charging sys.
You can test the charging system by starting the mower and then unhooking the negative terminal from the batter, if the mower stays running, the charging system is working, if it dies immediately the charging system is faulty, you can also use a tester at the engine to test the voltage at the connectors
Oct 12, 2013 | Briggs & Stratton Briggs Stratton...
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My ground speed is very slow can i adjust the travel pedal on my troy built 22 hp 46 in hydro lawn mower
I have the same machine, [pull plug wire for safety] tip machine on it's side, next remove blade, now remove all the plastic shields that are above blade right to the deck bottom. You wont believe the grass build up around blade shaft. On this machine as you select your speed the pulley travels on shaft, but with the grass build up the pulley can't move. I've done mine twice now in the last 4 years. You'll need around 3 hours, good luck it's not that bad.
Oct 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Rope on mower won't pull.
due to the ethanol and additives in todays fuel it can also be your carborator. one of the intakes may be clogged and all gummed up.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
