Question about BafoTech BAFO BF-1284 Parallel Adapter
BAFO 1284 returned by win 7 with code 43 message
When I connected the cable, win 7 ultimate 32 bit o/s did not install it and returned with code 43 error message
5 Suggested Answers
thumu
  • 69 Answers
SOURCE: Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Posted on Oct 17, 2007
SOURCE: bafo bf-1284 can't detect
I need a driver for BF-1284 in windows xp
Posted on Sep 20, 2008
SOURCE: bafo bf-1284 installs but doesn't wotk with printer
You MUST select THAT port exactly when setting up in the printer setup it will NOT find it automatically.
Posted on Feb 21, 2010
  • 5339 Answers
SOURCE: I have bafo-bf-1284 usb to
The BF-1284 driver (zip file) is available from BAFO support: http://www.bafo.com/menu-support.asp . Scroll down the list to the desired product. The driver is for Win98se and Windows Me. You shouldn't need a separate driver for Win7; the drivers should be in the OS. (See the link on Windows 7 compatibility near the top of the URL given above.) I suspect the driver should also be available in the OS for XP.
If your computer doesn't find the driver automatically, check if the driver is listed in Windows Update as optional updates. (You may have to manually check for updates.)
I hope this helps.
Posted on Jul 30, 2011
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
I was using TVSE Nova 130 printer on my pc parallel port with win xp pro os and it was working properly. Now I want to connect the printer to my laptop which has only a usb port. So I purchased a bafo...
go to device and printer. Locate your printer . right click the printer and select printer properties. click the port tab then change the printer port from LPT to usb port.
Jan 22, 2014 | Computers & Internet
I have bafo-bf-1284 usb to parallel converter but i don't have driver cd. problem creating to install this product in windows 7 or windows xp please help me.
I hope this helps.
Jul 30, 2011 | BafoTech BAFO BF-1284 Parallel Adapter
Windows 7 64 bit Is not installing drivers for BF810
Here are the drivers you need for your USB to Serial adaptor!
http://www.bafo.com/download/Driver/PC/BF-810%20DriverInstaller_v1210_windows.rar
~KenjiFox
Jan 07, 2011 | BafoTech BAFO BF-810 Serial Adapter
Bafo bf-1284 installs but doesn't wotk with printer
Feb 21, 2010 | BafoTech BAFO BF-1284 Parallel Adapter
D-link DU-562m does not work with windows 7 RC Ultimate 64 bits
Download from the following site.
http://load2.file-drivers.com/download.php?id=87889
Jun 09, 2009 | D-Link DU-562M Modem
Bafo bf-1284 can't detect
Aug 29, 2008 | BafoTech BAFO BF-1284 Parallel Adapter
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
BafoTech BAFO BF-1284 Parallel Adapter Logo
74 people viewed this question
Top BafoTech Computers & Internet Experts
David Payne
David Payne
Are you a BafoTech Computer and Internet Expert? Answer questions, earn points and help others
