Question about Dell Inspiron 530s Desktop Computer
Beeps twice then pauses and beeps twice again(repeats) and wont boot
  • Dell Master
  • 998 Answers
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Posted on May 01, 2014
  • 5100 Answers
SOURCE: inspiron 531s upon starting beeps twice and pauses
Assuming that you hear 2 short beeps and a pause before you hear 2 more beeps, your computer can not detect any memory during the power on self test. Turn off everything and unplug all of the cables. Then open the computer and carefully remove all of the memory in the machine. (Press down on the plastic latches that hold the modules in place then pull the memory stick away from the motherboard.) Replace one module and then try to reboot the computer. If this works, try the other stick(s). Try the modules in different slots until you know if any of the modules and slots work.
Replace with new memory if possible. The 531 can take 512 MB or 1 GB memory with the following specs: 667-MHz or 800-MHz DDR2 SDRAM.
If the none of the memory works in any slots, try them in another computer if possible. If the memory works in another system, then the motherboard needs to be replaced.
I hope this helps.
Posted on Sep 25, 2011
respect137
  • 157 Answers
SOURCE: my dell inspiron 531 is beeping when i try to boot
Ok with that issue your hard drive is either not connected correctly or your hard drive has gone bad.
Posted on Apr 10, 2009
  • 2666 Answers
SOURCE: Dell Inspiron 530 desktop won't
See here
Posted on Sep 03, 2010
nerdvana
  • 120 Answers
SOURCE: My dell inspiron 531s wont
"No memory modules detected"
You can check the documentation at the link below..has suggested troubleshooting..
http://support.dell.com/support/edocs/systems/insp531s/en/om/html/trouble.htm#wp1085300
Scroll down a bit and you will see "beep codes".
Posted on Apr 12, 2011
jryc32
  • 408 Answers
SOURCE: dell inspiron beeps twice , pauses beeps twice
This is the advanced troubleshooting section for most computers.
First thing to do is "reseat" the memory modules - Reseat, with the PC powered off first ground yourself to a metal part of the PC before touching the memory modules and then only handle them by the edges as they are static sensitive. Remove each memory module then reinstall and make sure it's fully and correctly seated. Try the PC and if there are still problems, try one memory module at a time in case one of them is defective.
If you find that this is information was helpful to you, please rate me and leave a comment as this will encourage me to do more free work for you and others. And please let me know if there's anything else I could help you with. Without any inputs we cannot proceed assisting... Thank you for using FIXYA! Best regards,
Junior
My hp prodesk 405 g1 mt keeps beeping 4 times in a row, pauses, then 4 times again. Repeats this process 4 times and wont boot with the power light blinking red. Help!!!
The beeping is a bios error code. Get the model of the motherboard and get manual to it . it should reference the beep codes to what the problem is.
Sep 09, 2015 | HP Prodesk 405 G1 A4/1.5 4GB 500GB W7P-W8P
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
A beeping noise came on and the air bag light does not come on
If you are hearing a series of 5 beeps, 5 beeps and then a pause and it repeats, the airbag light is burnt out, and there is an error that the LFC ( light Flash Code ) needs to report.
Pull the cluster, and replace the airbag light, and then pay attention to the LFC that will be given ( example, 1 flash short pause, 8 flashes, slightly longer pause, then repeat the 1-8 pattern again, jsut as an example ).
Feb 05, 2011 | 2004 Ford F150
I get a long beep then a pause and the beep reats.
More info here
http://www.computerhope.com/beep.htm
Oct 15, 2009 | Abit IC7 Motherboard
My presario 1600 just beeps when I turn it on...
there are 4 kinds of beeps that the pc produce when you turn it on, base on your beep it is indicating that the memmory is damage,
a single beep means the pc is ok
and your beep is memmory damage
a long beep pause and then beep long again means video card damage
if the beep sound like a firetruck the processor or memmory is over heating
Sep 24, 2009 | Compaq Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently and doesnt boot up as normal. The monitor is switched on but there is no picture. I tried another monitor with my hard drive and that worked...
Unplug power from the machine for a period of 5-10 minutes.
Plug it back in and attempt to boot. Carefully notice if there are any beeps again, and listen for pauses in between. Dell beep codes go in a three pulse pattern I.E. 4-Slight Pause-4-Slight Pause-2-Pause/ and repeat.
After this, you may have to open your machine and assure that everything is well connected.
There is a chance however that a major system component has failed and needs to be replaced.
Hope this helps.
Apr 13, 2009 | Dell Dimension 3100 PC Desktop
My dell inspiron 531 is beeping when i try to boot it. it beeps twice thne pauses and then repeats. last night is froze
Apr 08, 2009 | Dell Inspiron 531s Desktop Computer
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
Sep 16, 2008 | HP Compaq d530c PC Desktop
Atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
May 02, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Dell Inspiron 530s Desktop Computer   Logo
312 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
