Question about LG RH397H DVD Recorder
Subtitles appearing when on timer record on RH397D/RH399D
When DVD is on timer record subtitles appear which we cannot stop. This happens when the DVD clock is altered. The problem has been rectified by a savvy teenager but he is not around now. Please advise
SOURCE: Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Posted on Jun 13, 2010
SOURCE: Our LG RH397d/rh399d DVD /
Your DVD drive is having a problem. When this recorder starts, it checks the DVD drive for correctness. If incase your DVD drive is has problem in the ejecting mechanism then this will prevent your HDD from working correctly. Take the player to service center and fix the drive
Posted on Jan 26, 2011
SOURCE: recorded onto my lg rh397d/rh399d, want to copy to dvd
You need to read page 37 "Dubbing a title"
Select the title you want to record and select the Dubbing option.
Posted on Apr 20, 2009
  • 411 Answers
SOURCE: How do I turn off subtitles which appear every
There's a setting for close captioning in the video menu. Set it to Off.
Posted on Jul 06, 2011
  • 11800 Answers
SOURCE: Bought a LG Rh397D/RH399D HDD
Simple test: use a different system of connecting the player to the tv. If you have used the HDMI use the analogue ones (Composite video-yellow and audio -red and white) and the other way around. If your tv doesn't have HDMI then switch between the analogue outputs - Composite and S-video. Of course use another cables plugged in another sockets in the tv.
If it's the same then the defect is in the unit - the audio converter section from the main processor has failed. The only way of fixing that is by replacing the mainboard, which means that the unit is effectively dead, time for a new one.
Posted on Jul 24, 2011
Our LG RH397d/rh399d DVD / Hard drive recoreder will only turn on and display the Hallo message, and you can hear a clicking sound from in side. I have remove the power cord no change .
Dec 28, 2010 | LG RH177 DVD Recorder/HDD Recorder
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
Subtitles do not appear
Want subtitles must pick at the movie menu.
Jan 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Subtitles keep appearing on dvd programs. I
yesh their is a setting in the menu where you can turn this off
Aug 08, 2009 | Televison & Video
I would like to be able to record TV shows WITH subtitles/closed captions. I have a Hisense HD LCD TV with built in HD tuner. I would like to be able to record onto a DVD/VCR. I'm getting conflicting...
Hey, I have a deaf brother with this issue. What I done was route the AV output of the TV to the AV input of the recorder. Set your recorders source to AV1 (or whichever you use) and set your TV to the program you want to record, also turn subtitles on. Because you wont have your TV set to the input your DVD recorder is on, you won't be able to see the DVD recorders output, but thats fine. Just press record on the unit - you have to leave the TV on the channel it's recording. Now you should be recording TV with subtitles with no problem :D
Apr 27, 2009 | Televison & Video
I need to unlock the regional code on my DVD player
The code I found from a trusted website says:
  1. Press SETUP
  2. Scroll down to the padlock icon
  3. Press 0 seven times
    • Confirmation message appears
  4. Press ENTER
Which sounds like what you're doing already. This is for RH399D. RH397D may be different.
Apr 13, 2009 | Televison & Video
Recorded onto my lg rh397d/rh399d, want to copy to dvd
Apr 06, 2009 | LG Televison & Video
We have a RH397D digital recorder. We cannot get the subtitles to stay off. Every time we change channel the subtitles come back up again. Where do we go on the menu to keep the subtitles turned off?
Easy Menu
Setup
A – DTV Closed Caption - OFF (Make sure it is turned off) I am not sure what activates this to ENGLISH but it can be switched off.
Aug 05, 2008 | Televison & Video
How i can view divx whit subtitles (.srt, .sub.ssa)?
it is quite easy to play those anoying subtitles first name the same way both files (video file and subtitle file) example movie.avi movie.srt be sure that both files are in the same folder second: insert the cd/dvd in the yht-630 when the menu appears select the subtitle file using the arrow keys and press the "subtitle" key after this at the screen you will see -> subtitle selected finally select the file that contains the movie (again arrow keys) and press "ok" or "play " key the movie will start and the subtitles will appear. it functions with sub and srt files
Jan 25, 2006 | Yahoo YHT-630 System
LG RH397H DVD Recorder Logo
Computer Repairing
Computer Repairing
