Question about Hansgrohe Home
Water in shower not hot enough - Hansgrohe Home
  • 374 Answers
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 21, 2008
  • 34 Answers
SOURCE: triton t80i water only warm in winter
That sounds like a water heater problem, wheres the heater at in your home. If it is effected by the outside weather i.e. the heater is in a cold environment then it would effect the hot water output. try turning up the thermostat on the heater if it is gas then it should be knob on the outside if it is electric you will need to remove the top or the bottom cover and adjust it with a screw driver. If this does not work the let me know and we try some other things. With the weather/temp outside effecting the water temp in the shower then I have a hard time believing it is the shower its self.
Posted on Feb 06, 2009
  • 4 Answers
SOURCE: replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Posted on Feb 26, 2009
Bati99
  • 88 Answers
SOURCE: Water not hot enough coming from my power shower
The Redring Superflow 3000 was not produced after 2001. You can try calling the showerdoc 0131-538-4343 or going to showerdoc.co.uk
Posted on Apr 17, 2009
  • 127 Answers
SOURCE: WATER DELIVERED FROM SHOWER HEAD NOT HOT ENOUGH
I think some shower valves have a safety setting to prevent burning. maybe you could adjust that to be hotter.
Posted on Jun 23, 2009
How do I adjust my exacttemp shower valve?
Where it suddenly became not hot enough, it's probably not an adjustment. It sounds like the stem needs to be replaced
Feb 28, 2014 | Moen Home
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
I installed a 30 gallon gas hot water tank and sometimes i get strong water pressure but my hot water doesn't last long enough for 2 showers, but if i have low water pressure we can get in 4 showers. Any...
At a high pressure you are consuming more hot water. It sounds to me like the water heater isn't big enough for what you need. You can try turning up the heat thermostat on the water tank. If the water gets hotter you won't need as much for each shower and it will also recover faster at a higger temperature.
Mar 26, 2011 | Whirlpool Water Heaters
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
Water from my shower tower is not hot enough. I have hot water flowing from taps all around the house. Only lukewarm water from my shower tower. What is the problem?
what brand of shower handles do you have and do you have just 1 temp handle or is it separate hot and cold?
Nov 17, 2010 | Home
I have to turn on lavatory faucet at the same time I'm running the shower so when I taking a shower the water doesnt go from hot to cold. It seams that maybe the hot water demad that the shower requires is...
This is not an uncommon problem with 'flash heaters' of this type; for safety, they all require a certain minimum of flow before the gas supply is turned on. Some brands/models have a factory-set adjustment for the minimum flow rate.
You might locate the mfr.'s website, contact them and describe your problem. This can also be caused by the modern flow-limited shower heads not allowing enough water to flow to keep the heater turned on.
If you have a retired shower head, you might try replacing the one currently used to see if it allows enough flow to allow proper operation. Either way, it is a waste of water.
Aug 03, 2010 | Kitchen Ranges
Adjusting the scauld guard on a shower mixer valve
Uue a 1/8" allen wrench to remove handle to access the dial that set's the mixture of water.Remember or mark where it is and remove and reinsert counter clockwise about a 1/4 turn to start to you reach desired temperature setting. Be careful not to set it at a hot enough setting to burn you.
Once dial in place slide handle on and turn on to check water temperature.
Jul 31, 2010 | Delta & Single Handle Shower Faucet
I have a Titan tankless hot water heater. I get hot water from the faucets but not in the shower. Do you have a solution?
try opening the faucet and the shower at the same time. some shower heads don't draw enough water for the tankless to fire.
May 20, 2010 | Kitchen Appliances - Others
Replaced a moen cartidge and now the water is not hot in shower
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower not hot
There is a handle limit stop under the handle. Remove the handle with an allen wrench and you should see a plastic piece with a tab on it fit into the assembly. Remove it and rotate it slightly to allow more travel in the handle and reinsert. You will have to test it to see if it allows enough hot water to mix in. If it is still not warm enough repeat as needed. Once you have the water at a comfortable temperature reinstall the handle and enjoy.
Dec 31, 2008 | Plumbing
Home Logo
Top Hansgrohe Home Experts
Shehu Pro
Shehu Pro
 John
John
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
