Question about Mtd Garden
Engine diagram for powermore 139cc ohv - Mtd Garden
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Yard man mower 139cc OHV spark plug
You can purchase a boot puller or take a pliers and grab exactly on top of spark plug and pull off. Some do stick on harder than others.
Posted on Aug 17, 2009
  • 30 Answers
SOURCE: won;t start
Hi, it is possible that even if you changed gas, assuming water was in the tank as your original problem, that some stayed in the bottom. If you pump the primer while it fires up and it helps to keep it running, you still have some water.
Posted on Sep 09, 2009
SOURCE: where to find the spark pug on my 21inch 139cc mtd
It should be under a rubber boot between the valve cover *(stamped OHV or OHC) and the muffler.
Good luck and be careful. Dont pull that boot when the engine is hot!
Posted on Jul 18, 2010
rycgl
  • 1545 Answers
SOURCE: yard machine 139cc ohv. wont turn over. cleaned
Clean the brass bolt very well that holds the bowl on the carb. Pay very close attention as their are some very small holes in the smooth part of the bolt near the top, as well as the bottom. Use NO metal objects to clean this bolt.It is the main jet of the carburetor also. Once cleaned properly, your fuel flow into carburetor and engine should be restored.
Posted on May 24, 2011
420cc powermore ohv
I don't find any reference to an oil sensor on the 4P90JUB.
Aug 08, 2014 | Mtd Garden
Powermore ohv
could be a number if things, dirty carb, old gas, dirty coil contacts, bad spark plug. First try replacing the spark plug and if it is old gas remove and replace with fresh. if that doesn't do it then the carb needs to be removed, cleaned and blown out thoroughly with an air compressor. reassemble and reinstall. next is to remove the recoil housing and clean the coil contacts. the coil is attached to the spark plug wire. remove and with some old gas or wd-40 and a wire brush, remove dirt and rust from contacts as well as magnet on the flywheel. be sure to leave the proper gap between the coil and flywheel when you replace the coil.
Jul 24, 2014 | Yard Machines 11A54MC006 21Inch 139cc MTD...
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Oct 28, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
139 cc ohv engine is racing how do I turn down the idle
get down and look at the carb. a little screw on top will allow you to adjust the idle, but;, check the choke, it is stuck in place or mal functuning maybe, but turning the screw right or left will set idle
Aug 07, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Is this machine's engine a 2 stroke or 4 stroke
If the engine doesn't have a sump and oil filler cap, it is 2 stroke.
Aug 09, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Crazy question but where is the primer button on the yard machine 139cc 21" lawn mower???????
The primer button is usually on the carburator of your machine. Most of the time on the side of the carburator , but sometimes on the front of the carburator. GOOD LUCK.
May 29, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Yard machine 139cc ohv. wont turn over. cleaned carb and bowl. bowl gets gas but gas wont get into carb . think poss vacuum problem
May 24, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Where to find the spark pug on my 21inch 139cc mtd ohv lawn mower
Jul 07, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Aug 17, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
439 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
