Question about PLUS Vision Corp. U3 880 Multimedia Projector
PLUS U3-880. It stops after 10-12 seconds...
Hi, my name is Marco. I'm experiencing some troubles with my PLUS U3-880 projector. I have replaced the lamp, after having received it from an authorized dealer, so the lamp is really the original one.When I push the POWER button, the system starts normally, the lamp turns on and both the fans begin working. After 10-12 sec. the lamp turns off and the STATUS LED starts blinking in a slow way (the duration of the "on" position is 12 secs), the fans continue working. The manual says that there is something going wrong with the fans, but it is NOT true: the fans work perfectly as I said! Naturally, this failure puts the system in condition of not being able to serve any connections with PCs or other sources, except for few seconds. Please, could you help me to understand what really the problem is and if there is any solution you could suggest to me? Thank you hearty. Best regards. Marco
  • trvlntx Feb 27, 2009
    I am having the same problem with a PLUS U3-810SF and have also replace the lamp.
Hi Marco, Speak span? Did u fixed your projector U3-880? Which part was bad? Im very desesperated, please send an answer to me sound_architecture@hotmail.com and tell me pls which part was bad? I´ve already replaced the lamp, same problem, seems to be the logic board or fans but i cant reach these fans cause they´re look special, I´ll wait 4 ur answer
best regards
Richard
Posted on Jan 25, 2011
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes orange...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
Lamp burn out 3 time in 16months
clean out your projector. if there is a lot of dust and/or no air flow, the lamp will overheat and die. it needs to cool. use canned air and blow out any and all dust from inside the projector. make sure the fans work. also, don't buy lamps from "bob's lamps". get it from a reputable benq dealer.
Nov 10, 2009 | BenQ W500 Projector
SONY KF-50we610
Go to Instuction Manual of Sony KP-50WE610 page-13, there you will see details where is compartment of lamp in tv and how to open it.
Need further info, let me know.
Sep 26, 2008 | Sony XL-2100U Projector Lamp for...
BENQ PB2140 PROJECTOR - RESET LAMP AFTER REPLACEMENT
Hi Terence
Yes you have to reset the lamp timer.
How to do this :
1.) Hold in the up arrow key on the Projector for 5 seconds , a on-screen display will appear in the top left hand corner.
2.) It will read : Press left or right and then Menu or Auto.
Just follow the steps and the lamp timer will be reset.
Thanks for using Fixya !
May 19, 2008 | BenQ PB6100 Multimedia Projector
Problems changing lamp
Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
May 19, 2007 | Eiki LC XNB3 Multimedia Projector
PLUS Vision Corp. U3 880 Multimedia Projector Logo
300 people viewed this question
Top PLUS Vision Corp. Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a PLUS Vision Corp. Office Equipment and Supply Expert? Answer questions, earn points and help others
