Question about Kenmore Washing Machines
Kenmore Frontload Washer 970-C42062 Won't Spin or Agitate Anymore
Product No. : 970-C42062 Model No.: C4206 Description: Kenmore Front Load Washer I have opened the back of the washer. I have removed the motor drive belt which is in great condition and I then set the Knob-timer to the start of the "Regular Wash" and pulled the Knob-timer out. I immediately hear a hum AND the "door lock" light comes on BUT the motor does not run. When I pull out the "Asmy-disp drwr handle/trim" the hum stops and the "door lock" light goes off. I then removed the 6-pin plug from the "speed control unit" and with a multimeter, I measured the voltage for pins 5 and 6 on the harness. I do not get a voltage reading. I'm stumped as in what does this mean. Is the timer line switch or door lock/switch faulty? Or is the motor just not working? I need help troubleshooting this problem where the drum is not spinning or rotating. The "spider" part shows no corrosion whatsoever despite my washer being 10 years old! BTW, the washer drains so the pump is working. I could be wrong but I suspect an electrical problem vs a mechanical problem. Any help would be appreciated. Thanks!
4 Suggested Answers
  • 1028 Answers
SOURCE: Drum won't spin.
ck fuse on board with ohm meter in board ..cks open change motor bd..also possible door lock or door strike
Posted on May 01, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Washer has Elect smell; no pump, spin, or agitate.
The ECU/Controller has failed. Replacement is your only option.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Daniel S
  • 4323 Answers
SOURCE: Kenmore 42992 front load washer won't
Hi
As you have already cleaned the drain pump assembly and the pump is fine, you have also replaced the timer and now the door won't unlock for short period of time the issue is with the door switch-lock assembly. The control detects that the door is not closed due to the switch going bad and so won't start the spin cycle. The motor is now fine, and the issue is not related to pressure switch so the door switch should be tested and if bad replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 26, 2011
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
Where can I download a manual for a Sears washing machine Model 970-C42062-00. Thanks.
See the following for where to find the actual model number. Sears model numbers are usually in the format:
xxx.xxxxxxxx with the first three digits of 110 for whirlpool built machines:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=21&osCsid=0da65cea0e338fe930b1fde153a243f0
Then go to the following Sears site for PDF versions of their manuals.
http://www.managemylife.com/mmh/owner_manuals/search?query=970-C42062-00
Enter the model number and you should be able to download manuals on the product.
Feb 16, 2011 | Kenmore Washing Machines
Do you have a parts manual for a Kenmore front loading washing macnine model number 970-C42062-00?
The model # you gave is not valid.
Look for the silver metal tag usually found on Kenmore washer on the frame when you open the door.
There will be the model # xxx.xxxxxxx
Once located you can go here and using the correct model# get parts and pricing info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
Jan 05, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
187 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
