Question about Whirlpool RF365 Electric Kitchen Range
Whirlpool electric range won't stop buzzing
My electric range buzzes constantly. It seems to be coming from the clock, dial area. Unplugging it for a while used to solve the problem but even that doesn't work anymore. Is this an expensive repair? Would I be better off with a new model. This unit is about 9 years old.
4 Suggested Answers
yalmer
  • 552 Answers
SOURCE: buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
Posted on May 20, 2008
SOURCE: Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
Posted on Nov 04, 2008
SOURCE: Clock on a GE electric range is buzzing - how to disconnect it
Turn off power to range first!!!
You'll have to remove the back of the panel in which the clock is installed to access the back of the clock. There will be two wires attached to the clock. Just pulling one of these wires off will stop the clock.
I would suggest, however, that you pull both wires off, put electrical tape on the ends of the connectors, and tuck them out of the way somewhere around the clock.
Posted on May 03, 2009
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Jun 14, 2014 | Viking Stove/Oven/Range Timer Knob -...
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
I have a hotpoint ff 175 bp and the temperature dial on the fridge has staerted to make an annoying and very loud constant buzzing sound with only stops when it is switched to zero.. which is no good...
You will have to dismantle the control box and see if the buzzing is coming from the cold control or from a defrost timer which is usually in the same area and is more commonly the cause of a loud buzzing. Whichever one it is you have to replace it right away. This is not a complete model number so if you need more help then post a full model number. Good Luck Appliance Specialists
Dec 10, 2009 | Refrigerators
May 03, 2009 | GE JBP30 Electric Kitchen Range
possible to have abad relay on the circuit board itself, only real way to fix is to replace the control board assy
Nov 04, 2008 | Kitchen Ranges
TIMER IS BUZZING NON STOP.
how old is the oven? does it have a analog clock? If it does then turn the stop time clock and the buzzing should stop.
Oct 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Buzzing noise
May 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Jan 14, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Whirlpool RF365 Electric Kitchen Range Logo
194 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
