Question about Fujitsu Siemens Pocket LOOX T830 Smartphone
Poor reception for T830
I have had this T830 for about a week now. I noticed couple problems that were really bothersome: 1. It has very low senstivity for phone signals. A regular cell phone side by side (for Cingular) shows at least 1-2 bars better. 2. The PDA phone hang frequently, and the only way to reset the PDA is to pop the battery cover open, a pain in the neck since there is no opening or external reset. My Dell x51v PDA (or any other PDA) offers much easier way to reset the device. 3. There should be some way to guarantee the phone operation, even if the PDA function is dead. 4. There is no convenient volume control via buttons anywhere, and I have to use the stylis to adjust the volume. 5. Not quite sure if the time is automatically synchronized with the phone company. It did not appear to be. 6. No LED flash for the camera. 7. the 4 way navigation button, as well as the jog thing on the side jumps over way too many items in the calendar window. I cannot use the navigation buttn or jog to smoothly go from one appointment to the next. I already upgraded to the firmware image version 812 EMP7078, but it did not improve performance of the phone at all. I am in the San Francisco Bay Area.
Your Pda doesn't have a soft re-set button located next to the battery?
Posted on Jun 25, 2007
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
Merc C200 - Problem with aerial?
try takeing back out and see if the conection on the back has come off if not have a look at the conection its self
Mar 29, 2010 | 2000 Mercedes-Benz C-Class
Sound distortion comes and goes...
First of all, try to have this repaired under warranty. Usually these sets have a 1 year warranty. Second, make a recording of the problem. That will help the servicer to understand the problem.
If you are not successful at the warranty repair, the first thing to look for is a power supply problem or poor connections at the audio amp area. I will attempt to locate more details while you persue the warranty claim.
Please keep us posted.
Thanks,
Dan
Sep 19, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Grundig g6 airband in khz and poor reception
I think having the display showing MHz for the air band would have been a better choice on Grundig's part, but it really doesn't matter that much. Its just a matter of moving the decimal point to the left three places.
As far as getting better reception on the air band, here are some tips:
1. Use an antenna.
2. Try other antennas.
3. Find a known active freq.
4. Find a freq. low of FM spurs.
5. Turn up the volume.
I own and use a G6, and get decent results with it on the airband.
Aug 20, 2009 | Grundig G6 Aviator Radio Buzz Aldrin...
TomTom 930 says "Poor GPS Reception"
Try to reset device by using a paperclip or similar at bottom of unit...
Mar 16, 2009 | Tomtom GO 930 GPS Receiver
No am reception and poor fm reception - 2004 Kia Sedona
If the antenna is on the front, pop the hood, and locate where the antenna wire connects to the bottom of the antenna and make sure it is connected well. If everything checks out there, you will have to pull the radio from the dash, and look at the back of it. There will be a large black wire by itself connected to the radio. Push it in to make sure its connected as well. That could really be your only problem unless your radio happens to have a fault on the inside which is extremely rare. Hope that helps
Mar 15, 2009 | 2004 Kia Sedona
It gives an excellent reception but only for a while
There is a problem with the tuner section. I would first suspect poor solder connections. If resoldering the ground connections on the tuner fails to resolve the problem, a replacement can be purchased for $38.40 using part number: 8-598-594-30
Dan
Jan 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Alpine cda 9885 Poor radion reception
Your antenna wire could be loose behind the radio because sometime they will have to use an adapter because of the size another thing could be if you have a sirius/xm radio they will send you an adapter to cut down on the static for free also the adapter on the sirius could be loose or bad good luck
Dec 30, 2008 | Alpine CDA-9885 CD Player
T830 flash rom
I to all, sorry for my english. I have resolved this problem, with the PocketLOOX8xxFlashTool.exe. The tool first try to connect to the T830, then it show you how to reset the PocketLoox to reflash it. The sequence is:
1) Reset by pressing Power Button + camera button + factory reset; 2) insert the usb cable in the T830 or insert it in the docking with the Power Button + camera button pressed. When you insert the usb cable, on the screen it show a new message "New USB download mode". Now PocketLOOX8xxFlashTool.exe can connect to your t830 and reflash it.
Good luck
Giancarlo
Sep 16, 2007 | Fujitsu Siemens Pocket LOOX T830...
Fujitsu Siemens Pocket LOOX T830 Smartphone Logo
198 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
