Question about Refrigerators
How do i replace a fuse bulb on a westinghouse wse6100wa refrigerator
5 Suggested Answers
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
SOURCE: door handle clips replacement
iam looking for doors handle barcet for model no RS662V westinghousetwo door frigde freezer
Posted on May 02, 2010
SOURCE: manual for westinghouse refridgerater WSE6100WA
If you mean the regular manual it is downloadable from www.westinghouse.com.au , if you want the wiring diagram they wont supply it
Posted on Jun 21, 2010
caroldon
  • 17130 Answers
SOURCE: food freezing in Refrigerator Freezer
There is a normal setting of the thermostat for the fridge and freezer and you can select the fridge setting to be lower than normal than what is set presently.
If there is no change then the thermostat is not cutting off the cooling and so there is no control of temperature within the fridge. Allow the lowest setting of the thermostat in the fridge section to confirm this fault.
Posted on Aug 18, 2011
Replace lamp in Westinghouse RJ390P refrigerator
Refrigerator Repair - Replacing the Light Bulb (Frigidaire ...
? 1:39
https://www.youtube.com/watch?v=7yE0ZZBNISU
Nov 8, 2012 - Uploaded by PartSelect
Refrigerator Repair - Replacing the Light Bulb (Frigidaire Part # 5303013071) ... Kelvinator, Tappan, White ...
Refrigerator Light Bulb (part #5303013071) - How To ...
? 1:23
https://www.youtube.com/watch?v=1AQTDSn4VFw
Dec 20, 2013 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace theRefrigerator Light Bulb 5303013071 on ...
Jan 14, 2016 | Westinghouse Refrigerators
Why is my Westinghouse Fridge WSE6100wa not getting cold or freezer not getting cold. this is only happening at the top of both fridge and freezer?
Sounds like you had a coolant leak. This kind of problem you describe usually is something you need to have a repairman come out and check, & get his opinion & an estimate. Please don't do anything to try to figure it out or fix it for yourself! You could hurt or worse. If you cleaned the freezer recently, is it possible that you poked the inside of freezer? That can do it. Also, check the plug to be sure whether you think that sounds impossible or not. box, as sometimes that happens too. And I assume you already checked the dials you adjust for how cold you want it? There is a dial in each of your fridge & freezer. Other than that, seek pro help. Good luck!
Dec 04, 2014 | Westinghouse Refrigerators
Westinghouse wse6100wa problems
The problem post you placed here haven't enough details to provide a solution. Provide more details please.
Feb 07, 2013 | Televison & Video
Food freezing in Refrigerator Freezer ok. Westinghouse model wse6100wa. Have misplaced manual and need to know what temperature is correct and how to fix this problem.
Aug 18, 2011 | Refrigerators
Door handle clips replacement
Apr 16, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Jan 16, 2010 | Refrigerators
Manual for westinghouse refridgerater WSE6100WA
Dec 22, 2009 | Westinghouse Refrigerators
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
