Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Locate exploded drawing of poulan chain saw
I have a poulan 18 chain saw manual but no parts list or cross section drawing
  • Anonymous Mar 28, 2014
    Need manual for clink link chain saw
  • 2,176 Answers
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
Posted on Jan 18, 2009
Purchased like new PP4218 from local, bought for his son, after one tree, son lost interest. No manual with saw. What chain and bar do I buy as replacements? He replaced chain, not sure it is correct...
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
Jan 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
All my fuel lines fell apart. I do not know where they go.
All Poulans are similar, I am forced to believe your saw is a "2375 Type MyBestGuess".
An example IPL for a Poulan "2375 Gas Chain Saw Type 7" follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly: It is deceptive it appears the filtered line goes to the primer, it doe not! It connects to the carburetor input. Trace your existing lines and they will bear my fuel schematic out.
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
A typical fuel system and a couple of hints can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If your saw is not a Type 7, you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 04, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need a new primer bulb Poulan WildThing 42cc CS
Item 18 on the "Engine Assembly" detail IPL here:
http://www.ordertree.com/modelinfo/PWE/PP4218AVX-Gas-Saw/75.PP4218AVX-Gas-Saw.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If this is not your saw you can fin d your here:
Poulan.com
HTH
Lou
Jan 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you replace the fuel lines
This should help. Snap a photo then a small sample of each to your local chainsaw seller.
The link is a Poulan 2375 Gas Saw Type 7 IPL.
If not your saw you can find the correct one here:
Poulan.com
If you have more questions you can reply below. I hope this is helpful.
Lou
Am replaceing fuel lines think i might have them crossed need diagram
There is an illustration on the link that should provide what you ask.
The IPL for your saw can be here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
Try PP4620 AV Gas Saw. HTH
Lou
Jan 03, 2010 | Poulan Pro Chain Saw 46cc 20"
How do I hook up a fuel line to a carbuertor on a Poulan 18 inch?
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/thumbs/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Poulan.com
The dash number of your serial number is the type. HTH
Lou
Dec 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
18 inch poulan wildthing doesn't want to start, doesn't seem to be getting fuel.
I suspect your fuel lines have failed, pretty common since use of ethanol in fuels. The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. It does show components and part numbers. Find it here:
Poulan.com
Typical fuel system:
b57ab47.gif Fuel Line Replacement by SmallEng.com
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine.
Nov 07, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Ryobi Elec Chain Saw ECS-2040
The number you provided don't cross to an exploded parts list.
The drawing can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
I advise you find an authorized repair facility for your own safety. HTH
Lou
Jun 23, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain brake Assembly
A drawing of a Poulan Wildthing can be found here:
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-1/75.2375-Gas-Saw-Type-1.1.59.1.html
Click "
View the illustrated parts list [Go]"
There are multiple drawings, this one may not be the correct one. The detail isn't very good but this is the best illustration for your saw. The "Handle, Chassis, and Bar Assembly" shows what is available. GL
Lou
May 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
901 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
