Question about GE Spacemaker JVM1640SJ Microwave Oven
I can not find this part: KW3AT-16, is a door switch and I need 2 of them.
When I close the door of the micro, the light and the motor still running and do not let me warm up the food.
Fan and light come on when door closed!
Door ailment may be a issue or the brackets that hold the switches maybe old and moving. Or wrong switch in wrong spot..
Nov 10, 2015 | General Electric PVM1870 Microwave Oven
Replaced the 20amp fuse in my microwave. Clock and all lights work but oven will not heat
one or more of the door micro switches are open or shorted..the micro switches tell the unit the door is closed and safe to use.the micro switched are marked normally open or closed..take note when replaceing them..also their is a actuator lever that tells the switch to close or open..it is plastic and connected to the door latch..it can be broken off or bent from heat,,its plastic..make sure its in place and working the micro switch
Aug 15, 2014 | Microwave Ovens
Why does microwave run with door open?
Very dangerous! Do not use it like that. I heard of a chip shop owner who has overridden the micro switch to make the oven run constantly. He could then just put food in and take it out without having to open and close the door. He eventually last his hand due to the exposure to the radiation. It must have something preventing the micro switch disconnecting. The micro switch is inside one of the holes where the closing mechanism pushes in.
Apr 23, 2014 | Kenmore 63792 Microwave Oven
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
Mcc1010t magic chef micro/convection
follow this steps and fix it. God bless you
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Jul 13, 2013 | Microwave Ovens
Start button an 1/2 buttons on keypad no work in my GE JVM150H microwave. Interior light also stays on.
The door has latch switches that are part of the protection and operation when door is closed, is the new door identical and switches match up {same number} if everything checks and the door switches are all working, the door needs to be checked for alignment, if it's out a small margin the switches will not operate properly.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave light turns on and vent fan runs when door is closed. It heats fine and functions work fine. It is not heating or counting down when closed, just light and fan.
You have a shorted door switch, not a difficult repair. You will need a micro switch and knowledge of microwave repair to replace this switch.
I hope this answered your question
Aug 05, 2011 | Microwave Ovens
My sharp R-798 has stopped heating food and the turntable no longer rotates?
Please check your door safey interlock micro switches.
If you need help with this, please let me know.
What frequently happens is because you probably open the door while the oven is running, (like most of us do) the little micro switches get burned and eventually cannot tell the oven that the door IS, indeed, closed. When the door is "open" (forget that you know the door is closed - the MACHINE needs to know it too) the oven will not turn on the heat.
If you need more info, let me know please.
Oct 18, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
210 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
