Question about Dishwashers
Hi,just bought an omega dishwasher model odw704xb,keeps coming up with error codeE1,i am on tank water but have good pressure
Have checked all hoses and inlets
  • 641 Answers
SOURCE: Water filling does not stop
Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and as well to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. Good luck !!
Posted on Jun 24, 2006
SOURCE: IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Posted on May 06, 2007
  • 210 Answers
SOURCE: "E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
Posted on Jun 07, 2008
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Posted on Apr 06, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
We keep getting an error message E1. We have an LG 2120 model
The E1 or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Dec 13, 2014 | LG Dishwashers
What is error message e15
What brand dishwasher? Model number might help too.
If it is a Bosch this might be the answer.
The E15 fault code means that the dishwasher is not receiving water through the water supply hose, or at least that what the machine thinks anyway.
E15= Check Water Inlet supply*
This can be caused by several reasons.
1. The filters in your inlet hose or inlet valve are blocked and need cleaning.
2. The inlet water supply valve is faulty and worn out, not allowing water in fast enough in relation to the set amount of time it takes to fill the machine for washing etc..
3. The water supply isnt turned on fully underneath the sink?
You will need to undo the water inlet hose from under the sink and check to see if there is a filter in that end of the hose and check to see if it needs cleaning. It will be of the wire Gauss type.
If not, then you will need to uninstall the dishwasher and pull it out from the cabinet to check the inlet valve where the inlet hose connects to at the bottom rear of the machine.
The valve itself will have a filter, where the hose attaches to. Undo the hose and visually check the filter in the valve for blockage/restrictions.
If the above brings no results, then you probably need a new inlet valve for the dishwasher.
Sep 04, 2014 | Dishwashers
Omega dishwasher
You should actually disconnect the hose from the dishwasher end and check that water can go through it, otherwise it could be a faulty anti-flood device in the hose.
Failing this, you may have a faulty inlet solenoid.
Jun 01, 2013 | Dishwashers
Washer not draining
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Nov 20, 2012 | Kenmore HE2 Plus Front Load Washer
Whirlpool - hot inlet hose shaking badly when filling water
check to see if the screen is clogged were water hooks up to back of michine
May 11, 2012 | Whirlpool Washing Machines
Model LD 12AW2 not drawing water displaying 1E error
Hi afarugia,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jul 10, 2011 | LG Dishwashers
Gets a 1E code. already checked water is on
Hi shadyron11,
Kind Regards :-)
Jedemeyer1
Jul 08, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
