Question about Fisher Paykel EcoSmart GWL15
How to run a diagnostic on fisher payke gwl15
2 Suggested Answers
ebabor
  • 4 Answers
SOURCE: fisher paykel gwl15 won't pump out water
My F & P Model GWL15 did the same thing. I purchased a new pump but that was not the problem. Tip the machine back and look under. There is a valve diverter that I removed and checked. There was a dime and lots of lint stuck in the valve so it wouldn't move back and forth anymore. I downloaded a parts manual, page 10 and item # 23 is the valve diverter. Once I unclogged it and put it back together, it worked great. I noticed it works better than it has for a long time. I'm a 60 yr old woman so anyone can do this. Good luck.
Posted on Oct 29, 2011
Fisher and Paykel EcoSmart GWL15 won't drain at the end of it's cycle. I put it in diagnostic mode and the got it to drain that way. I ran another cycle and it wouldn't drain on it's own again. Put it back...
Hello Robert. If you have heard any kind of squeaking or squealing or rattling while the pump was running, replace the pump. You mention a humming noise. Also a sign to replace the pump. When FP pumps fail, they will not spin at the correct speed and that is why when you run it in diag mode you can pump out the water as it runs until you stop it, but will not drain in a normal cycle. Be VERY careful when you replace the pump. Make sure you get no water in the new pump windings when replacing the pump or you will WILL take out the machine controller. Pump p/n is 479595
Apr 09, 2014 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
I have a gwl15 Fisher Paykel Smart Drive and it will not get past the rinse cycle, water will not drain out! I found the diagnostic mode sheet and the number I come up with is none of the fault...
Hi - it would seem the washer pump may actually be blocked for some reason... If you had followed the method as per the diagnostics then if you reckon you got 35 then its a communications error beween the console & display. Furthermore you would be able to mannually start the pump in diagnostic mode to see if its working fine.. But under normal cond..... the machine would come up with a pump error & code 37 - so perhaps it is ok.
Remedy - check the harness wire connections between the display & the controller unit is good - clean - otherwise replace the display unit to correct.
On the error codes - there is a Code 35 - just that its not available to the public - it was only ever issued on a DVD sent to the service agents - have never actually seen it on the secure service site.
See how you go....
Jul 11, 2011 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and paykel gw509 not draining, pump is clear
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Mar 04, 2009 | Fisher Paykel EcoSmart GWL15
Hae we have a fisher and paykal washing machine but it wll not start spinning can u help
Run a diagnostic test for the spin cycle. The paper to show you how to run these test is located under the control panel normally two screws on the back of the control panel. By running the diagnostics, it will code if there is a problem and you will know what to check. You can also drain your machine with these diagnostics.
Does your machine beep (because there is a problem) during the drain process but doesn't get to the spin cycle? More than likely your drain hose is clogged. It is very easy to check this. I had the same problem because my machine could not drain properly and would not get to the spin cycle. There was a penny in my drain hose. There is a video on youtube that shows you how to do this (very informative).
Jan 19, 2009 | Fisher Paykel EcoSmart GWL15
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Mar 25, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
70 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
