Question about Canon X25 Toner Cartridge for imageCLASS MF5500 Copier
Ho to refill Cannon Imageclass X25 toner?
Hi There,
I have purchased a Imageclass X25 toner refill kit. The instructions are not clear. Can you tell me how to get the instructions from web?
Thanks,
Francis
    Problem Solver:
  • 6 Answers
Thank you for sharing this information! I know how you feel, I am looking for someone to help me with my <a rel='nofollow' href="http://www.InterFusionMEDIA.ca">home theater installation</a>, I already tried to do it myself, that is not going to happen!
Posted on Apr 15, 2011
You're only asking for problems trying to do it yourself. It' extremely messy, and more involved than simply adding new toner. and the refill kits are a scam. Find a reliable supplier, and get a remanufactured unit with a guarantee, if you're looking to save money. Cartridges are designed to go 1 cycle, and then require a new drum, cleaning blade, doctor blade, bushings, toner, etc. The cartridge includes not only the toner supply unit, but also a waste section, that, even if you were to refill somewhat successfully, the section will begin to overflow, causing further problems. Cut your losses.
If you're local. I can help:
http://www.hotfrog.ca/Companies/Sandman-Sales-Service
Posted on Feb 16, 2009
  • helmet veshdon Mar 11, 2011
    Sandmanmac is right, this job can get really messy, really fast. I would just have a professional do it, unless you wanted office cleaning services to go with the solo job.
How far do i pull out the tab on the x25 canon cartridge
Hi!!
Pull it all the way!It will end as soon as its done!!!
Cheers!!!
Jan 22, 2011 | Canon X25 Toner Cartridge for imageCLASS...
It doesnt conect to my labtop, i installed the cd also
Are you for real????? You are tring to connect a laptop to a toner cartridge???????
Sep 24, 2010 | Canon X25 Toner Cartridge for imageCLASS...
I have bought 2 OEM canon X 25 toner. They print came out blur and patches.
do you mean that on the printed/copied picture the toner isnt "baked" and it smudges down?
If thats the case that means that you have fixing film problems and the cartridges are OK.
Hope that helps!
Aug 23, 2010 | Canon X25 Toner Cartridge for imageCLASS...
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
How i can refieling cartage
Its best that you go to web page of OASIS IMAGING, there are detailed instructions for Canon and HP remanufacturing.
But the most easyest way that you punch, or drill, or with soldering iron make an hole in crg, fill with toner and tape the hole.
But I recomend the Oasis whole procedure.
Jun 02, 2010 | Canon X25 Toner Cartridge for imageCLASS...
Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
www.tonerrefillstore.com
www.lasertekservices.com
They also have great customer service. I hope this helps!
Nov 08, 2009 | Brother DCP-7040 Laser Printer
Canon x25 toner cartridge
Don't try and refill this on your own, you'll only have difficulty. Buy a reasonably priced compatible, that is "remanufactured" -not 'refilled'. It's not just toner that makes it work. The drum, cleaning blade, and doctor blade (at minimum) need to be replaced for proper operation, and there is also a toner waste hopper that needs emptying or it will overflow on second cycle.
Just my 2 cents.
Mar 31, 2009 | Canon Office Equipment & Supplies
Refill Toner Cartridge for Laser Printer
Nobody has a clue how to refill a laser cartridge with ink. :)))
OK< just kidding, here it is:
First of all, laser-cartridges have toner (a fine black powder) and not ink.
Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
But because from your question i see you dont know a thing about refilling, better go to a refill center.
Feb 14, 2008 | HP LaserJet 1012 Printer
Canon X25 Toner Cartridge for imageCLASS MF5500 Copier Logo
1,669 people viewed this question
old marine
old marine
