Question about Frigidaire Ovens
Frigidaire bottom heating element not working in oven. Top element works.
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Early 1960's Frigidaire 24" Double wall oven not heating
    Hello Chris Hammond, thanks for your post!
    Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
    Nov 07, 2014 | Ovens
    Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
    I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
    Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
    Frigidaire wall oven CPEB30S8CC2 lower element does not work
    We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
    Jul 16, 2012 | Frigidaire Ovens
    Are the top and bottom heating elements both supposed to heat? Only the bottom one is heating except when specifically set on "broil".
    Most ovens with top and bottom elements have a multifunction control switch which enables the user to select a certain setting to suit their cooking. The control switch would normally have small pictures of the elements, fan forced function etc, to show what each setting does. Sometimes you may only require the bottom element working and other times you may want/need both.
    Feb 14, 2011 | Frigidaire Ovens
    Frigidaire wall over model number CGEB30S8AB1 is not heating. It is just the bottom bake element. I tried to replace the element but it is still not working. I can hear the relay clicking but it will...
    I had this problem a year ago (both elements worked in top oven but only broil element worked in the lower of the dual ovens). I swapped elements around but the problem was still the bottom element bottom oven.
    So I called the repairman. He replaced the relay board (Part #AP2127301) for the lower oven, and it worked again. Yippee.
    But now a year later, I have the exact same problem. Lower element on lower oven is not working (Frigidaire you have got to be kidding)!
    However this time I decided to take a look at the relay board myself, to at least save the expense of the repairman. I looked closely at the board and thought I saw a cold solder joint on relay K4. But just to be safe I touched up all the connections on all the relays with flux and a soldering iron.
    Works perfectly again !!
    Please if you try this, disconnect the power first. In fact if I had to tell you that, then just call somebody.
    Oct 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
    Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
    We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
    Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    My frigidaire oven won't heat. The burners work
    You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
    Aug 23, 2009 | Frigidaire Ovens
    Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
    Ovens Logo
    142 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal DeAngelo
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
