Question about Vector 2M Pwr Rch Spotlight
Need the charger for vector 2 million spotlight
Model VEC157
SOURCE: Need adapter for Vector 1 Million sport spotlight Model VEC156
if its the one im thinking of, i had the same problem.
if you look at the back and theres the male prongs to plug into the wall
well what i did was i took off the back
then i took off the cradle that held the battery in place, and stood it up on the lens and simply plugged it into the wall to charge it.
its kind of complicated but simple way to save some dough in todays market.
Posted on Dec 03, 2008
SOURCE: Charger
call 952-884-9191 its dewalt and black and decker factory service they bought out vector.
Posted on Jan 21, 2009
  • 973 Answers
SOURCE: My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Posted on May 27, 2010
  • 973 Answers
SOURCE: Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
Testimonial: "Thank you so much!! I do appreciate it!"
SOURCE: I have a Vector VEC 189 10 Million candle power
I have this same light and have lost the charger. can anyone tell me where to get one. Thank you
Posted on Apr 01, 2011
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Mar 27, 2012 | Vector 1 Million Rechargeable Spotlight
I need to know where I can purchase a charger for my vector spotlight mod.156
Vector is made by black and decker. you should be able to get a replacement from them. possible there is a service center close to you to get one from. http://www.blackanddecker.com/Service-Centers.aspx
Dec 28, 2011 | Vector 1 Million Rechargeable Spotlight
My vector vec157 will not charge on 120 volt. It works on 12 volt
If you light is charging when you use the 12v automotive charger but not when you use your AC power transformer, my thought is that you might have a problem with your AC charger, not with the light itself. I have AC/DC transformers from the 1970s that still work fine, but I have had numerous modern AC/DC transformers burn out on me in recent years.
One easy test is to use a multimeter to measure the output voltage of your wall charger. Place one test lead on each of the charging terminals (i.e., one inside the barrel and one outside the barrel, if you have a standard coaxial charging port) and check the DC reading. If it's zero--or anything less than 12 volts, actually--the charger isn't working correctly. The problem may be a torn or cut wire or something actually inside the transformer.
Replacement chargers can be found at Radio Shack and other stores. You may also be able to score a cheap replacement at a "dollar plus" store or even at a second-hand shop. Make sure that the terminal polarity is correct on your replacement charger or else you'll fry the batteries in your light.
Sep 08, 2011 | Vector 20 Million Power Series Spotlight
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
Where can I purchase the charger cord for the Vector Sport Spot 20 million Power Series?
BELKIN MAKES A UNIVERSAL AC/DC CHARGER WITH WORKS VERY WELL. MODLE F3A114 - ALSO RADIO SHACK MAKES UNIVERSAL CHARGERS AND THERE REASONABLY PRICED. IT LOOK LIKES BLACK AND DECKER BOUGHT OUT VECTOR, AND IS HANDLING THERE SALES. HOPE THIS HELPS! MATTHEW
Nov 07, 2010 | Vector 20 Million Power Series Spotlight
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
Jun 13, 2010 | Vector 3 Million Candlepower Rechargeable...
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Vector 2M Pwr Rch Spotlight Logo
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
