Question about Rain Computers Computers & Internet
My monitor shuts down with a dialog box that reads (auto detect digital input entering power save)
Getting a dialog box that says: (auto detect digital input entering power save)
SOURCE: digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
Posted on Oct 19, 2007
Fix-4U
  • 293 Answers
SOURCE: my LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Posted on Oct 13, 2008
SOURCE: dell monitor dialog box says monitor is in the power save mode
Actually, it most likely is not the monitor which is in "power save mode", it is the computer itself.
When you cannot get a computer out of "power save mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty.
Usually, this happens on a computer which is a few years old, since its batteries will have run out after such a long time. (The motherboard battery is used to store various settings when the computer power is off, such as date and time. When your computer detects this battery is empty, it goes into a low-power mode).
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Posted on Dec 07, 2008
  • 8 Answers
SOURCE: Monitor not seeming to work when computer is powered up.
Hi there!
Try reseatting the video card and clean the video card if needed and the memory module.
Posted on Mar 07, 2009
  • 3278 Answers
SOURCE: dell vista will not boot up
Typically, it's a memory problem. If you have multiple memory modules, leave one in the CPU at a time and boot your system todetermine which module is bad. Good luck.
Posted on Jun 27, 2009
Auto detect input analog entering power save
Okay boss, does your computer remain on when this happens?
Jan 14, 2014 | Dell OptiPlex 760 PC Desktop
Tip
Protecting your documents with password !!
You can protect your document by applying password so that unauthorized person can not display as well as modify your document. You can apply two types of passwords:
Password to open the document:
If it is applied then you have to give the correct password to open the document, otherwise you cannot open the document.
Password to modify the document:
If it is applied then you have to give the correct password to modify the document, otherwise your document is opened but you cannot modify the document. It means that your document becomes read-only.
To apply a password to document, follow these steps.
* Open Save As dialog box by selecting "Save As" command from File menu.
* Click "Tools" button of Save As dialog box and choose "General Options" from drop down menu, "Save" dialog box appears as shown in figure below.
* Enter first password in "Password to open" text box and second password in "Password to modify" text box (if required) and click "Ok" button of dialog box. Microsoft Word will open "Confirm Password" dialog box for the confirmation of passwords. The maximum length of password is 15 characters.
* Re-enter the password to open and password to modify and click "Ok" button of Confirm Password dialog boxes one by one.
* Click "Save" button of Save As dialog box.
on Mar 19, 2010 | Computers & Internet
Tip
Protecting Document with Password
on Jan 29, 2010 | Computers & Internet
Auto detect analog
You can try reseating Monitor Cable on both ends.
Test Monitor on another Tower/Desktop PC? Vice Versa.
Let me know if it works
Thanks
Jan 14, 2014 | Dell Computers & Internet
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
Before Windows can boot-up the screen turns solid blue & a Dialog Box state "Entering Power Saving Mode". The screen then appears that the sleeping mode has occurred.
just switch off and switch on the monitor or press any button on keyboard to bring monitor from power saving mode thats all
Sep 23, 2010 | Dell E207WFP LCD Monitor
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
LENOVO DESKTOP HAS GETTING AUTO SHOUTDOWN PROBLEM HOW TO SOLVE THIS
when does your PC auto shuts down? at what particular time or when what particular task you are doing?
1. Right click on any blank portion of your screen and click Properties. Display Properties then shows up like below.1e949c6.jpg
2. Then click the Power button under the "Monitor power" group to bring up the Power Management dialog box like below.
These settings when turned ON will shut down parts and peripherals in your PC but not the entire system. If after checking this part the problem still continues, then better download, install and run the Malwarebytes Antimalware to remove malwares known as the pc-off.bat that triggers the shutdown command.
Oct 26, 2009 | Audiovox Computers & Internet
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
Dell monitor dialog box says monitor is in the power save mode
Dec 06, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
20 people viewed this question
Top Rain Computers Computers & Internet Experts
David Payne
David Payne
Are you a Rain Computers Computer and Internet Expert? Answer questions, earn points and help others
