Question about Craftsman Garden
Craftsman blower/vac won't start 358.794765
Have spark-- Have fuel-- Won't even try to start.
Sears sells what they call a "carb kit" P/N 545081857. It\'s a complete carb for $30 + shipping + tax. I\'n throwing near $50 after a $90 blower that didn\'t make it a full year. Not to mention that I spent half a day calling uninformed (but personable) clerks at Sears asking them about gasket kits for a carb. They just make up stories, like "bring it in, they will know what to do in the store" or "They have the parts in the department"
Posted on Oct 12, 2013
rotorcrafts
  • 302 Answers
SOURCE: Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
Posted on May 19, 2010
#1 Taper
  • 1041 Answers
SOURCE: craftsman blower won't start( 24cc 2-cycle)
You may need to do two more additional things.
First, check the fuel lines for cracks/breaks.
If they are o.k.,then you will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 13, 2009
  • 257 Answers
SOURCE: cant get my 25cc craftsman blower to start...
try checking to see if spark plug firing ,, if it is not firing the magneto is bad,, just follow the plug wire and you find it,, here is a way to check the fire,, take spark plug out take a pair of rubber or plastic coated pliers and hold to some metal while someone pull it if you dont see spark then this is your problem,, hope this help you
Posted on Sep 02, 2009
  • 124 Answers
SOURCE: I have a Craftsman Blower/Vac model 358.794770
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
Posted on Sep 14, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
My blower sounds like the carburator or something is loose and it won't start easily and when it does it won't stay on or doesn't have good power
With the unit off, grab the carburetor and see if anything is moving. Sound like the cylinder may be loose. Before tightening cylinder screws check if the gasket is damage. If yes then change gasket.
Nov 12, 2012 | Craftsman 2-Cycle 27cc Handheld Blower/Vac...
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Just replaced carborator and now it won't start. any suggestions?
you might have primer bulb lines on backwards or the gasket between carb and motor is upsine down
Aug 25, 2012 | Craftsman 2 Cycle 25cc Handheld Leaf...
Blower won't start
do you have spark?is the gas 30 days or newer ?
Jul 05, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
Garden Logo
520 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
