Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have an older side by side ge fridge with the panel display that shows pf - power failure de - cc etc well the de light has come on and I don't know what it means - I do not have the manual and I'm not sure what the problem is and what to do.
    President:
  • 373 Answers
The DE error comes up when the refrigerator has not detected adefrostcurrent within a certain amount of time. This is most often theresultof a burnt out defrost heater. The refrigeratorwill likelykeep working for a week or so until the frost builds up andblocks theair flow over the evaporator (the cooling coils behind theback wall ofthe freezer). The defrost heater is located at the bottomof saidevaporator.
You can try your zip code in http://www.geappliances.com/buy/ and look for a servicing dealer.
Good luck.Please rate my answer if accepted.Thank you.
Posted on Jan 18, 2009
I have a Maytag dryer model: MEDE300VW0 that is showing a PF code. I have tried unplugging, pressing the cancel button, etc. as recommended on various internet sites. PF code persists.
i know that the voltage overseas is different form the usa,that's telling you there was a power failure while the dryer was running,check the back of dryer to make sure you have 240 volts going to the dryer,you could have a bad power cord or something to do with power source.
Feb 06, 2018 | Maytag Dryers
The oven overheated and now a PF is on the face
Good Afternoon Friend,
I understand that your Frigidaire range, model# GLHS269ZDB, overheated, and is now showing a "PF" code displayed on the control panel. The "PF" code means that there was a power failure. You can clear that by pressing any button. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
We had a power failure and Kenmore stove showed pf and now loc. cannot get burners to turn on and cannot get loc off.
If you have a power failure or a brown out, it sends a very powerful current through the unit. Please keep in mind that these units are not protected against any surges. If you have a display, that means you have power. Unfortunately, the clock/timer contains relays that control the elements, the oven, etc. You will need to replace the clock to get it running again.
Mar 13, 2014 | Kenmore Stove / Oven / Range Bake Element...
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
Oct 23, 2011 | Whirlpool Ovens
Got code PF and control keypads not working?
Hello :
PF indicates power failure . Displays this message after it has been unplugged or if there has in fact been a power failure .
good luck .
please rate !
Apr 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
PF ?
Not actually dead, just apparently unresponsive.
PF means power failure. It either got reset or unplugged, etc.
If it's not responding to the keys, then you likely have a shorted keypad or trouble on the control board.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JES1238 Microwave Oven
GE refrigerator Model no TFG27PFX
I have no manual either and i would also like to know what the diagnostic panel letters mean too?? Mind is flashing CI.
kim
Oct 16, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
220 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
