Question about Vehicle Parts & Accessories
Ford Fiesta Quartz 1995 - alarm
I disconnected battery when re-connected the alarm keeps going off and unable to stop it. Can you advise.
    Sergeant:
  • 227 Answers
If you have a remote, use it to cancel the alarm after battery is connected. Also look for a valet switch that overrides the alarm. Have to turn the Key on then hit the valet switch. If car will start but has alarm sounding find the speaker and cut the wire.
Posted on Jan 19, 2009
My ford fiesta 1.6 L 2015 suddenly stops while driving at low speed and the engine didn't start again..!!!! any body face the same problem..??
disconnect battery earth first leave for 10 mins reconnect -they have been known to do this when the battery has a dead cell so turn your headlights on see if they go dim first--- if so new battery time
Dec 28, 2016 | 2015 Ford Fiesta
I am unable to start my Ford Fiesta Edge 1.4 none of the lights show on the dashboard and I am unable to lock the car electronically. Please advise
It is a process of elimination, start with battery, do your headlights go on, and if so, when you attempt to start car, do lights dim, or not. If they dim, then battery is low or a bad cell exists which prevents starter from turning over engine. Most often it will be a corroded battery terminal, so check for white ash like substance on polls and connections to battery, loss of continuity is common problem whereby lights may come on, but starter which draws the most from battery will be the indicator of bad connection. Good luck
Oct 22, 2017 | Cars & Trucks
I put a new battery in my 95 Ford escort When I reconnected the cables and the green wire to the positive the alarms went on and the car will not start. After a couple of minutes the alarm stops. What do...
most cars with alarms will trigger the alarm when the battery is reconnected.
you should have remote in hand when you connect the battery and be ready to press the unlock button on the remote
Sep 10, 2011 | 1995 Ford Escort
I installed a new battery on my 95 vw golf, however when I connect the terminals the alarm sounds on the car. How do I install it without the alarm sounding?
just connect the terminals,and wait till the alarm stops(30secs)then UNLOCK/HOLD KEY OVER 30 secs,windows go down.then lock/hold key over,windows go up.then press remote unlock button for 30 secs,you have just reset the alarm system/central locking/window comfort facility.....has to be done EVERY time you disconnect battery........
Nov 08, 2010 | 1995 Volkswagen Golf
Central locking not working
Assuming that the battery mentioned above is the Key Fob battery?
The usual solution to the key fob not working the Central Locking after battery replacent  is to remove the car battery feed fuse   to the Central Locking (or disconnect the car battery )  for 10 minutes...replace it..... then it should work OK
note: If you disconnect the Car Battery then make sure you have the radio security code.
If not then POST A NEW QUESTION quoting your radio Serial Number (usually begins with M * * * *  * * )
Sep 25, 2009 | Code-Alarm Code Alarm Transponder
1995 ford escort, alarm keeps going off and car wont start
The alarm brain should not be the easy to locate if stock. Put everything as it was. The alarm brain, control, module or whatever any one wants to call it is most likely behind and under the radio possibly on the floor but in that area. That is if it is OEM if not then it should have been installed under the instrument cluster. I should be a small box probably held with zip-ties and it should have all the information, manufacturer, model and wire functions on the brain. If you think he found the right thing then have him look for the red wire that connects to it. It should have a 15amp fuse on the cable. If its taken out this will disable the alarm. What ever he found should say Security, Alarm or something like that. Not door control or anything other.
Jun 20, 2009 | 1995 Ford Escort
Ford fiesta radio won't recode
you need to disconnect the battery for half hour or so this often resets the radio LOCK.
Feb 22, 2009 | Code-Alarm Code Alarm Transponder
Ford fiesta 1994
is it a foctory alarm? or an aftermarket alamr? if it is factoty
just lock and unlock the door with the key, but if not let me know.
Jun 22, 2008 | 2000 Ford Focus
Vehicle Parts & Accessories Logo
234 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
