Question about Sharp Audio Players & Recorders
CD-BK270W has 3 CD in, won't play, it reads ER-CD11
Enclosed 3 disc closed and did not play, reads ER-CD11
  • 236 Answers
SOURCE: cd tray stuck closed
if you are not a tech expert, i would suggest that you bring the unit to service center ahd have them remove the CDs themselves. you have to remove some screws in the mechanism of the changer and you may acidentaly damage the lense. Just be careful when you carry and transport the unit not to tilt on either side. you have to keep it up straight always to prevent the CD falling out of the tray.
Posted on Mar 31, 2008
Beelz
  • 666 Answers
SOURCE: THE SYSTEM SHOWS ME ER-CD01
this is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo mode. now press the power button while pressing the stop and eject button,clear all will display
hope this helps
Robb
Posted on Apr 23, 2010
SOURCE: The 3-Disc Rotary Changer will not eject. Error ER-CD11 appears.
notice sharp 3 disc rotary changer en français; svp
Posted on Nov 26, 2010
gopakumarg43
  • 75462 Answers
SOURCE: I have an old JVC
Hello
There are two possibilies for this faut. The first one is related with its Laser Pickup Unit, and the second one is related to its loading mechanism. If loading mechanism did not load disc properly to to the holding disc drive motor, disc wont play, and will be ejected as it enters into the system. i don't know, how old your system is, and how much it used so far. Anyway try first by inserting a head cleaning disc into the tray and play it for two of more time. if this does not help you try replacing the loading belt. You have to open your system to do this work. Loading belt can be located at the loading mechanism, fastened with its loading gear and loading motor. If this also does not help you, there is no other way than replacing the laser Picup Unit with same type and number. To repalce either belt or laser pickup unit, you have to open and disassemble the mechanism itsef to do the work. If you are not aware in electronics, and not so experienced in doing this type of work, get help from an other who knows these well. Most of the [90%] of components used in this section are made of high density plastic, and can be damged easly. If any wheel in loading gerar mechanis has broken teeth with it, also will poise this probelm. So it also should be checked.
Anyway you have to open and disassemble the mechanism as a whole. OK
Posted on May 25, 2011
kenw392
  • 2226 Answers
SOURCE: 2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Posted on Jun 01, 2011
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Jan 03, 2014 | Sharp HE CDDH950P Mini System
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
What does U1 mean when it appears on the pioneer cld v860 display window and the disc won't play?
It sounds like buy your details, That i will compliment you on, Are to the point not like some other people asking questions on hear, That the lazer is shot, End not reading the info off of the disc any more, It is verry costly to have it repaired, Just look for a different one, I have got good used ones for friends of mine for $7 to $30 at the most, From thrift stores or privately, Hope this helps you out.
Nov 11, 2012 | Audio Players & Recorders
Pwr. on but won't play cd,
The lazer is not reading the info off the disc any more, It is costly to have them (Replaced) $180 to $250.
Nov 01, 2012 | Yamaha CDC-655 CD Player
Tray #1 won't read cd most of the time
Hello
Insert a lens cleanig disc into the device and play it at least three times. If the fault is due to any dirt or dust accumulated on lasser pickup lens, thei will rectify the problem. If this does not help you, the laser pickup lens unit of your device should be replaced with same type and number. The lens cleaning disc can be bought from most of the electronic sparepart shops at your town, and won't cost more. OK.
Jan 29, 2012 | American Audio Mcd810 Dual Mp3 CD Player...
Displays no disc when Cd is player
Hello
Put it an other good known disc, which the set has played without any problem at all. If it also doesn read it, and displays no disc, the Laser Picku unit of your set has damaged. Put in a lens cleaning disc into the player, and play it for at least three times. If the fault is due to accumulation of dust or durt, the cleaning disc will clean it, and your set will be OK. If not repalce the Laser Picku Unit, sith same type and number.
The lens cleanig disc can be bought from most of the electronic sparpart selling shops at your town, and won't cost more. OK.
Jan 23, 2012 | Sanyo DC-DA1000 CD Shelf System
Cd player won't play disc it says
Hello
Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
Jan 19, 2012 | Panasonic Audio Players & Recorders
Displays ER-3:
According to the manual er-3 is a "Servo error or the disc is in upside down". I wish i were kidding but that is what the manual says.
Sep 01, 2008 | Durabrand DB1200 CD Player
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
