Question about Crime Stopper Vehicle Parts & Accessories
Van alarm is draining battery flat over night
The van is a citreon berlingo
  • 112 Answers
I doubt it is the alarm, but a simple way of checking is to unplug it.. look under drivers dash for an aftermarket box, unplug the connections (after charging battery) and wait till next day.. I think you might have a diff issue (I have installed these for over 10 years and never seen one actually discharge a battery)
Posted on Jan 26, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
My citreon berlingo alarm keeps going off every time I turn off the engine, how can I stop this?
Welcome to French car electrics! Nothing is simple on these. Get help from an electrician/tech or remove the alarm fuse. Sorry, but they are a nightmare.
Nov 03, 2015 | Cars & Trucks
Citreon Berlingo van. Need to unlock radio but dot have the code,can thius be done.
u can buy an unlock code on ebay from £2.99 you will need to take out the radio from the dash to get the serial number.
Jul 01, 2015 | Cars & Trucks
Engine idle speed on citreon berlingo 1.9
Warm diesels should idle low. Some of them 800-900 revs.
At cold, they should have a fast idle, some 1100 revs.
look if your engine has a cylindrical device, with a bowden cable to the diesel distibutor pump. This will be your coldstart device, responsible for idle revs.
Aug 09, 2014 | 2005 Citroen Berlingo
How to set timing up on 1.6 Hdi engine without reluctor after cambelt snapped
please state year and model of this engine as they do change ,i think its a citreon something like a berlingo or maybe a 306 or whatever but need the year as the common rail is different to the injector pump model or is it a dreaded my favourite motor and thats a renault
Feb 29, 2012 | Citroen Cars & Trucks
The oil light on my citreon berlingo van 1.4 petrol will not go off and the stop light flashes and beeps intermittently. I have put about 3 or 4 litres of oil in and there does not appear to be any leaks...
Have you checked the oil level, is it in the norm?, if its normal and still get light, then possible faulty oil pressure sensor. The brake light... are you disengaging the parking brake all the way?, have your parking brake sensor and oil pressure sensor checked out.
Good luck
Aug 19, 2011 | Aston Martin DB7 Cars & Trucks
Door vibration rattle on off side new berlingo how do i remove door panel citreon
Remove all the screws in the panel, then pop out window and lock controls if you have them, then take a large flat tip screwdriver and pry the rest off. Then lift up and off.
Jul 16, 2010 | 2006 Peugeot 405
Radio not working after battery flat on my citroen berlingo van
You may need to enter a security code to reset the radio.
Sep 04, 2009 | Car Audio & Video
Wiring an alpine cdm9807 rb to a citreon berlingo van
The 'illumination' wire is to hook up to your headlight switch to back-light all buttons when headlights are on. The pink and black audio interrupt I believe is for hands free cellphone communications it will cut out audio when you have a call and have your hands free hooked up through your stereo. The remote turn on is for external amplifiers it provides a small amount of power to to turn on/off external amplifiers. As far as your unit not working I would make sure you have a sufficient ground using a voltmeter and make sure your battery lead is fused and fuse is not blown. You should have a memory lead(maybe yellow) that need constant 12v and a ACC power that needs switched power that is only on with key(usually red). Hope this helps! :)
Feb 25, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
287 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Frank Mangiapane
Level 1 Expert
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
