Question about In Win (IW-ISP300J2-0) (isp300j20) 300-Watt Power Supply
Shuts down during high graphics usage
While playing WOW system is fine til a high graphics/ heavy usage situation then you hear an audible "click" & system shuts down.
  • tazwegion
    tazwegion May 11, 2010
    What type, brand and specification PSU are you using? your VGA may not be getting sufficient voltage under intense graphics loading...
    Problem Solver:
  • 19 Answers
Get a new 450 watt to 500 watt power supply
Posted on Feb 21, 2009
Whenever I play a video on my laptop it shuts down after a few minutes?
Many laptops don't cool as well as they should - try elevating the rear of the laptop - heavy video usage could be causing the shutdown.
How to Fix Overheating and Shutting Down Laptop
Feb 18, 2015 | Computers & Internet
Tip
How to cross check your ISP charges your Internet usage fairly
I personally use NetWorx. Witch is a free and simple, yet powerful tool that helps you objectively evaluate your bandwidth situation. You can use it to collect bandwidth usage data and measure the speed of your Internet or any other network connection. NetWorx can help you identify possible sources of network problems, ensure that you do not exceed the bandwidth limits specified by your ISP, or track down suspicious network activity characteristic of Trojan horses and hacker attacks.
The program allows you to monitor all your network connections or a specific network connection (such as Ethernet or PPP) only. The software also features a system of highly customizable visual and sound alerts. You can set it up to alert you when the network connection is down or when some suspicious activity, such as unusually heavy data flow, occurs. It can also automatically disconnect all dial-up connections and shut down the system.
The incoming and outgoing traffic is represented on a line chart and logged to a file, so that you can always view statistics about your daily, weekly and monthly bandwidth usage and dial-up duration. The reports can be exported to a variety of formats, such as HTML, MS Word and Excel, for further analysis.
With NetWorx you can
• Find out and monitor how fast your Internet connection is.
• Find out and monitor how much Internet traffic you consume.
• Verify whether your ISP charges your Internet usage fairly.
• Detect a suspicious network activity on your computer.
• Perform simple network tests such as ping and trace route.
• Be notified about excessive Internet usage
You can download it from here.
Please Vote for this Tip if you found it helpful J
on Jun 07, 2010 | Computers & Internet
Cant even run wow >.> ok, I just bought a gaming
Whats your FPS in wow? (Can be seen by hovering your mouse over the Game Menu sign (the questionmark)).
Is it only low in cities with a lot of players or is it just low overall?
Nonetheless lowering the graphics will obviously help.
Just press Escape to enter the Game Menu, and then press System, and go to the Graphics tab.
You could lower the overall graphics by taking the slider down, but I believe the most important things you should do would be:
Multisampling: 1
Shadows: Low
View Distance: Fair or Low
I would also lower Texture Filtering and Texture resolution.
The thing is I am not entirely sure how the things will change when you use the slider, but I would definitely recommend just trying to slide all the way down at first. If the settings I mentioned above are higher than I posted, I would put them down as well.
Especially Shadows can be a real FPS killer.
The View Distance has no real affect and is just for the looks.
Your PC should be able to run WoW fairly well if you adjust the settings. If you wish to increase the performance without lowering the settings I'd recommend buying some more RAM though.
Anyway, tl:dr:
Press Escape to enter the menu, click System -> Graphics -> turn the slider all the way down to Low. Make sure the shadow settings is in fact on low as well. All the settings under the Effects tab can all clear up some fps if lowered/disabled.
Sep 20, 2013 | Blizzard Entertainment World of Warcraft...
VIDEO PLAYS WITH NO SOUND ON WINDOWS 7 TRIED REINSTALLING BUT STILL NOT WORKING
First try uninstalling the version you are using and install the latest version 5.2, Then open an .swf file in the player and close the file. Now open the video file you were trying to play. The sound must be audible. Try this solution, if the sound was audible in other video players and not audible with MPCStar player.
May 12, 2011 | MpcStar
I start to play battelstations pacific ,it will play fine for 5 to 10 min. the you hear the fan come on and the screen go's black and gets stuck and i have to shut it off
It is possible for the cooling system may not function properly and the CPU or video card is too warm. Try to open the case, if the system is no longer under warranty and see if there is too much dust. Try running the system with case open and see if it's the same situation.
Apr 10, 2010 | BFG Technologies BFG GeForce GTS 250 OC...
My computer doesn't work a application program
Make sure your system meets the minimum requirements for the game.
Operating system: 2000/XP Processor:1.0GHz. Memory:256MB Hard Drive: 1.2GB
DVD ROM:8Speed
Video Card:32 MB
Sound Card:direct X 9.0c compatible
If problem is with loading or playing with graphics, there are controls in the game that allow you 'shut down' some of the graphical effects that can help get the game working. Also, shutting down unnecessary programs like instant messengers can free memory needed for game. Right-click items in task area (lower right corner) and exit or close items you don't need during game play.
Bret
1-2-1ComputerServices
Oct 07, 2009 | EA Sports Cricket 07 for Windows
Slow gameplay
Does your machine meet the games minimum requirements?
If so have you tried turning the graphics down in your game interface?
Laptop Graphics cards usually use your systems memory so they have a harder time rendering complex graphics. I play WoW and have my graphics turned up on my desktop but have them turned down to minimal for my laptop.
Vista also takes allot of system memory thus leaving less for your video card. If you are going to play games on it on a regular basis I would suggest you have a minimum of 2GIGs of memory.
Jan 12, 2008 | Computers & Internet
Monitor shut down
It is possible that you are playing the game at a higher resolution than your video card can support. Even if your computer is capable of displaying a high resolution during normal browsing activity, that doesn't mean it can support the same resolution during graphics-intensive use. Try turning down the resolution and the quality in your game options and see if the problem goes away. I ran into this same issue when trying to power a 1920x1200 monitor with a GeForce FX 5200 Ultra and discovered the solution is either a lower resolution or more graphics power.
Regards,
Javabytes
Nov 19, 2007 | Evga GeForce 7800GTX KO 256MB PCIE Graphic...
Monitor Shutdown problem
I believe the problem is from the herzian synch windows wants to achieve, either too low or too high.
You ought to try with a different monitor, either to set the synch or to make a analasys if it's another problem we're facing, like graphics card or motherboard itself.
Nov 15, 2007 | ASUS A9550GE/TD Radeon 9550 Graphic Card
In Win (IW-ISP300J2-0) (isp300j20) 300-Watt Power Supply Logo
90 people viewed this question
Top In Win Computers & Internet Experts
David Payne
David Payne
Are you an In Win Computer and Internet Expert? Answer questions, earn points and help others
