Question about HP Photosmart C5280 Printer
Printer Alignment Failed in HP C5280
I installed new blac 74 cartridge and reinstalled color 74 cartridge in my HP C5280 printer. It tried to print out a test page, but now telling me (after more than one try) that printer alignment failed. What do I do?
  • 2 more comments
  • khwalz Jan 18, 2009
    I'm very pleased to have received a response so quickly!
  • Anonymous Mar 03, 2009
    I have the same problem, and I have cartridges installed. But the alignment message keeps showing
  • Anonymous Mar 18, 2014
    I have tried to "align printer" and "it failed" - only printed in cyan.....will not perform "clean cartridges" or "print quality report" - factory defaults are restored - I don't ever remember changing them.
  • Anonymous Mar 26, 2014
    No able to print in color
  • 2,120 Answers
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Posted on Jan 18, 2009
  • Leroy Elliott
    Leroy Elliott Jan 18, 2009
    It was my pleasure. Thanx for the Fixya!
I replace my cartridges it says refer to printer documentation and will not print
These types of severe HP 74 black or HP 75 color ink cartridge errors (i.e. refer to documentation / incompatible cartridges, print cartridge(s) problem, etc.) typically indicate the internal micro electronics of the respective HP 74 black or HP 75 color cartridge are damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal micro electronics failure. I suggest you first run a Tap 41 diagnostic test to check cartridges electrical health (this is a special forced service test, refer to video so you understand how to read the print out). You may also bypass the error (temporarily) on most models which use HP 74/75 cartridges.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding:
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report:
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
NOTE: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions:
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
NOTE: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions:
However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
*Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active electrical state of both cartridges.
For additional printer diagnostics information please visit:
NOTE: If you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (with ink compatibility or color output/richness) with all of these models:
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 74/75 original/genuine ink cartridges is only suggested!
HP 74/75 Ink Refilling Services & Additional Cautions:
If you ever need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty and free shipping over $20 (products available to US residents only).
HP 74 Cartridges:
HP 75 Cartridges:
For any additional questions please contact us directly:
-Thank you
May 21, 2015 | HP Photosmart C5280 Printer
HP Photosmart 7525 printing blank pages
Do a hard reset of the printer . Since you can print out a status report that indicates that the hardware and cartridges are good but that the software or electronics, may be bogus.
If you go to HP they will refer you to a forum or advise you to get a new printer -an HP, of course!
Aug 25, 2017 | HP Photosmart C5280 Printer
I installed new COLOR 75 cartridge . It tried to print out a test page, but now telling me (after more than one try) that printer alignment failed. What do I do?
Follow the steps on this HP link:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 01, 2011 | HP Photosmart C5280 Printer
I just installed my brand new printer cartridge in my hp a526 printer (NEW) and when I follow the instructions for set up to perform printer alignment it failed and will only print re and yellow colors...
First of all if there is a procedural fault when a new ink cartridge is installed this fautl can occur.
So first of all remove the printer, Uninstall the software. the reinstall the printer software and on instruction connect the printer to the PC. The new harware will be now installed .
make a test print. It must work fine.
Failing this test there can be errors in the printing head / main board.
Sep 11, 2010 | HP Photosmart A526 photo printer
Hp photosmart c5280 all-in-one printer........the color ink cartridge will not allign
I had a similar issue, I called HP Support and they had me change out the ink, re-run the alignment, restart, change out the paper, run the alignment again. They had me try everything you could imagine. But, in the end; there was absolutely nothing that would fix it. They said that pulling paper jams from the printer among other things (if not done properly) can permanently damage the print head to where the alignment can no longer correct it. Luckily, while it took forever, the printer was under warranty...I had to do a warranty repair, but the new printer had no issues.
Mar 08, 2010 | HP Photosmart C5280 InkJet Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a Photosmart C5280 Have changed colour cartridge for the first time Alignment has failed twice Book tells me to contact you Print cartridge alignment failed.
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
then try to print if the alignment fails then you need to change the cart in the
printer if its original hp new cart then get replaced .....
Good luck..
Jan 06, 2009 | HP Photosmart C5280 InkJet Printer
Hp c5280 printer
Its the cartridges...... you will have to get more or new ones. I changed mine after a week of fiddling around - and printer worked perfectly. Wish the error message had been specific, then I would not have wasted all my time. The cartridges that didnt work were brand new HP 350 and 351 cartridges - straight from the packets, but the printer "didnt like them"..... A waste of money but Im going to try and put them back into machine tomrrow and see if I can fool it!!!
Jun 08, 2008 | HP Photosmart C5280 Printer
HP Photosmart C5280 Printer Logo
3,810 people viewed this question
Ben Johnson
