Question about Arris Nvg510 At&t Uverse High Speed Wireless Gateway Modem/router
Nvg510 won't connect to xbox live
I keep getting an IP address error every time I connect.
SOURCE: xbox 360 live troubleshooting
Assign a static IP address to the 360, then go into your router's setting and set a DMZ for that static IP.
Posted on Dec 12, 2007
Bubbabear64
  • 2794 Answers
SOURCE: cannot get motorola 5101 to
Clarification request is solution.
Posted on Sep 29, 2008
  • 3 Answers
SOURCE: No Internet Connection
get better quality digital  T spliters, better qualitly coax R5 cables, replace all your sppliters connectors, ask cable company to get a direct line to their Tap box and make sure there is at max only one spliter before your modem and that the cable comming from their tap box is not longer that the necesary.
regards.
im very impresed nobody post anything to you all this tieme.
Posted on Apr 27, 2009
  • 489 Answers
SOURCE: cant connect to xbox live need an ip address how do i get one
When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is 192.168.0.1. The next machine powered on will normally get an IP address of 192.168.0.2.
Posted on May 30, 2009
  • 277 Answers
SOURCE: need default IP
Default is 192.168.100.1 so make sure your PC is 192.168.100.2 (or higher than .2) to connect.
Posted on Oct 18, 2012
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
I've had xbox live for like 6 months now and had a terrible connection but could still play even with the biggest lag ever but now i cant do anything xbox live wont work now and has only started...
When your mom reset the router, the gateway IP address was reset and that has made your Xbox unable to reach the web. You need to go to your settings in the Xbox and reset the IP addresses so that they are able to reset the connection. This may require you to go to your computer and get the addresses from it and reconfigure you Xbox IP's accordingly. If you are not sure how to do this, let me know and I can walk you through it.
You can get more information on it from here:
http://support.microsoft.com/kb/967572
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 30, 2011 | Video Game Consoles & Games
I bought a new DSL-2642B Wireless Router and Modem but it won't let me connect to Xbox Live, the solution that the Microsoft Solution thingy game me was to change the MTU settings, any idea of how to...
In order to connect to Xbox Live with a Wireless Modem and Router, you will need a Xbox 360 Wireless Adapter. You can get a Xbox Wireless Adapter cheap on eBay, or you can buy it Microsoft at Gamestop. http://www.gamestop.com/browse?nav=16k-Xbox+360+Wireless+Adapter
To find your MTU Settings, follow these steps.
1. Click on 'Start'
2. Click on 'Run...'
3. In the bar, type CMD, and hit enter.
4. A black box should appear. Type "ipconfig" without quotation marks in the field.
5. Your IP Address, Subnet Mask, and Default Gateway codes should pop up.
6 Go to your internet browser and type you IP Address into the URL box.
7. You should find MTU settings, and you can set them to your desire.
May 28, 2011 | Microsoft Xbox 360 Console
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
XBOX 360 LIVE
try u turning of the power in the router and the Xbox check if the ip address is automatic in the Xbox tried resetting the xbox to factory settings  if did not work out try resetting the router and the xbox and reconfuguring check if the xbox is getting detected in ur router
if still did not help u out keep me posted asap with error i ll fixya
Nov 01, 2008 | Microsoft Xbox 360 Console
Xbox 360 live
find the IP adress on ur router if its wirless
May 16, 2008 | Microsoft Xbox 360 Console
Wireless connection of xbox 360
you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Nov 25, 2007 | Microsoft Xbox 360 Console
Arris Nvg510 At&t Uverse High Speed Wireless Gateway Modem/router Logo
393 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
