Need manual need a manual that shows wiring hookups to a receiver and a equalizer
  • Audio Player... Master
  • 1,258 Answers
Ron there is no such manual except those that might come with the Equalizer- Actually , the process is very simple. You take the output of the equalizer in hook to tape in. Tale the record out of the tape loop and hook to input of the equalizer. Then the equalizer will work when the tape look (tape monitor) for the receiver is selected- that is why it is called a tape loop as signal goes out and comes back in. If you have Pre outs and Pre in you could use it there too. In the tape loop connection any tape deck is then hooked to the Equalizer tape inputs- some have two.
Posted on Jan 02, 2013
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
I have a Fisher CA-871 and all componets, I misplaced the hookup digram for the amp to all componets. The problem i have is only the EQ-871 to CR-W870 and also to tape deck. I hope you can help Thank...
if you visit the link below you will find hookup diagram for your need..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
How do I wire my equalizer into my audio system?
http://installationsplus.com/docrepair/hookup.html
Jun 23, 2011 | Audio Players & Recorders
Need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
May 01, 2010 | Yamaha RX-V463 Receiver
Diagram of pioneer receiver vsx-454 to show wire hookups
This site has the manual for downloading. You need to register but it's free.
Feb 28, 2010 | Pioneer VSX-454 Receiver
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Hookup
It would help to know what equalizer you have, but I will assume it is a stereo analog unit. With the exception of the Tape In/Out connections on the back of the receiver there is really no provision for an equalizer. Even the Tape I/O connections are of little use if you can't monitor the source through the Tape In connections. Even if that were to work, it will not function for any digital sources you may have. You should be able to install this between an analog external source and the input to the receiver if you have one particular device you would like to tweak.
There are equalizer settings you can control within the receiver itself. You have the option of selecting the manual method for equalizer settings for each speaker or the default automatic method. Granted there are only 5 frequencies (3 for the sub) that you can adjust, but the fact that you can adjust each speaker separately is an advantage. The following was taken from the owner's manual:
• The front, center, surround, and surround back speakers
can be adjusted at 80 Hz, 250 Hz, 800 Hz,
2500 Hz, and 8000 Hz. The subwoofer can be adjusted
at 40 Hz, 80 Hz, and 160 Hz.
• While the Direct or Pure Audio listening mode is
selected, the equalizer settings have no effect.
• This procedure can also be performed on the AV
receiver by using its [SETUP], [ENTER], and arrow
buttons.
This is a very good receiver with some great features. If you have performed the Automatic Speaker Setup, you can go to the equalizer setting and select Off, Audyssey (automatic) or Manual.
Hope this helps.
Oct 15, 2008 | Onkyo HTR500 Receiver
Yamaha 5.1 receiverhookup to teac equalizer
record output from receiver to linein of eq,and line out from EQ to PLAYBACK of receiver Thank you very much albie 20
Sep 29, 2008 | Teac EQA-120 Home Equalizer
Equalizer hookup
record out from receiver to line in in equalizer and line out from equalizer to playback in receiver-------but you have to check the result by yourself and watch if it is better than befor or not,
Aug 17, 2008 | Audio Players & Recorders
Equalizer hookup
general rule of equalizer connection as following:-.
preamp out-------equalizer---------amplifier---------------loudspeaker.
Jul 06, 2008 | Audio Players & Recorders
media out(dvd-cd) to equalizer in ------equalizer out-------to aux in or line in in receiver.
May 25, 2008 | DBX 1215V Home Equalizer
57 people viewed this question
 Grubhead
Grubhead
