Question about Urban Outfitters Boomphones Phantom Headphones - Black - One Size
Boomphones they cut out at the input inside of the headphone I have to wiggle the jack around for it to work
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
42LD520 sound shorts out
if it has a headphone jack it could cause this--the jack when inserted cuts off the speakers to engage a headphone--try inserting a jack when it does this and wiggle it a little--jack socket has leaf contacts that can be out of position
If tapping it could also be a bad solder connection somewhere.
Apr 08, 2012 | LG 42LD520 42 in. HD-Ready LCD TV
Input jack on my hp541 kicker headphone's sound comes and goes. I have tried multiple cables, If I wiggle the cable around it works in one speaker sometimes both.
Hi hotrodjayrod,
If the symptoms remain the same after trying another headset, this kind of fault is caused by bad solder joints in the earphone jack itself of your unit. This is due to frequent inserting and pulling the headset plug. To resolve the issue, the earphone jack must be re-soldered. You have to open the back cover of your player and using a pointed soldering iron, re-solder the joints.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 20, 2011 | Kicker HP541 Headphones
The jack peice will only work if i wiggle the wire around.
Your jack is probably loose, the only solution is to reconnect, or solder it.
May 29, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
How do I fix a bad connection with the headphone jack on my ipod touch? When plugged in, the music is static-y. It is definitely the headphone jack that is the problem.
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
Jul 23, 2009 | Apple iPod touch
Acer Aspire 1406 no sound issue
So sometimes laptops play up when the headphone socket gets a bit worn. If you wiggle a headphone jack in the socket (put it in at different angles, and rub around) sometimes the sound will come back.
There are two prongs that "detect" the headphones, and cut the speakers... and if they don't "un-contact" when the headphones are removed, the speakers stay off.
You'd need someone to solder a new headphone socket on the mainboard to properly fix it, but if you wiggle and get the speakers back, they should stay back until you use the headphone socket again.
Apr 20, 2009 | Acer Aspire 1406LC Notebook
MDR-7506 - No sound on right side
It sounds like the pin cracked. If this is the case, you'll need to soldier a new jack on it. Here's how, assuming you already know how to soldier a new 1/8" TRS phono plug.
Cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Nov 01, 2008 | Sony MDR-7506 Professional Headphones
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
Headphone jack problem
Most likely the solder points inside the unit where the headphone jack attaches to the system board have come undone. If you know how to solder, you could open the unit and fix it. If that is not an option, you could resort to using the other headphone jack instead assuming it is not damaged as well.
Apr 10, 2008 | Insignia NS-DV2G MP3 Player
Urban Outfitters Boomphones Phantom Headphones - Black - One Size Logo
188 people viewed this question
Top Urban Outfitters Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Urban Outfitters Audio Player and Recorder Expert? Answer questions, earn points and help others
