Question about Speed Queen Washing Machines
How to remove timer knob from speed queen washer machine aa5421L
Model AA5421L
  • 958 Answers
SOURCE: Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Posted on Aug 02, 2008
SOURCE: timer replacement
the knob, actually, unscrews. pull out the knob as if you are starting a wash cycle, and use needle-nose pliers to hold the back, and unscrew. i learned the hard way when i pulled on it like it was one of the other knobs and yanked the post out.
Posted on Dec 02, 2008
  • 117 Answers
SOURCE: How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Posted on Mar 02, 2009
  • 1294 Answers
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Posted on Mar 06, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Posted on Jul 24, 2009
How do I replace the timer knob on Speed queen AWM351W-3062 ?
The problem may be mechanical failure of the timer rather than the knob, especially if you have to push or pull to start washing.
Aug 20, 2016 | Speed Queen Washing Machines
How can I remove knob from timer?
Some machines use push on - pry off knobs. On older machines, the prying off process can lead to destruction of the cheap plastic knob.
Feb 15, 2016 | Speed Queen Washing Machines
How do I replace broken washer cycle selector knob on speed queen top loader
Hello there and thank you for choosing fixya
These knobs are normally the pull off type so all you have to do is get a small flat tip screw driver behind the knob and gently pry it out to get it started then it should slide off
However if you are needing to replace the entire part then the top back section of the machine may need to come off it may even have some screws behind the white side plates that allow to be removed and the top part folds up and back allowing you to axcess the part ok this part is usually held on by 2 or 3 screws
Jun 29, 2011 | Speed Queen AWN412 Top Load Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Dec 21, 2008 | Speed Queen AWS75NW Top Load Washer
Speed Queen AWM 373 w3062w
I would start by checking the lid switch, you should hear a click when you open and close the lid. If this is ok we will move on to the timer.
The main power comes thru the timer when you pull out the timer knob the main power is fed to the machine. if you try and start the wash cycle multiple times will it occasionally work and then not. It so replace the timer. the p/n is on the back, it will be an RSPC number, typically 5 or 6 digits.
Then go to Partselect.com or repairclinic.com or a local parts house since you have an Export model for the Asian area I believe you may need to find someone local. The price on one I would think about 85 USD.
Let me know if you have questions. I can tell you how old it is if you send the serial number. Your choice.
T
Aug 21, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
141 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
