Question about Canon PIXMA MP620 All-In-One InkJet Printer
Error code "6A80" from Canon PIXMA MP620
Just installed new Canon PIXMA MP620.  When asked to turn "on" button on, I get error message 6A80, "printer error as occured.  Turn off power then back on again.  If problem persists, see the manual"  The manual does not address this problem.  Live Tech support in closed on the weekend.  I have turn the machine off and on several time with the same message appearing.  HELP!
  • 122 Answers
SOURCE: I have a canon mp620
(a) Left up the cover to reveal the ink cartridges
(b) Move the ink / print head to the left hand side
(c) Look to the right under the flap where the ink would sit when printer is powered off
(d) underneath there is something in white that is flat - this is called a wiper.
(e) push this wiper with your fingers - pushing in the direction toward the front of the printer - you may need to do this a few times.
(f) power off and then power on (using button on the front and NOT by pulling the power out of the back)
Posted on Feb 28, 2011
komguy
  • 2306 Answers
SOURCE: I have a printer MP620, and get a error 6A80 need
6A80 can be either a sheet feeder error or a purge unit error, either can be caused by paper scraps or other debris caught inside. You need to inspect closely with a flashlight and remove any scraps, beyond that you may need a shop to take apart and replace gears or even a purge assembly.
Posted on Oct 22, 2009
IB4G2008
  • 3587 Answers
SOURCE: Canon Pixma MP150 service error 5100
sounds like an engine failure..from that code..is this under warranty, by chance?
Posted on Mar 25, 2008
SOURCE: Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Posted on Jun 29, 2008
  • 421 Answers
SOURCE: Message error 6A80
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Posted on Dec 07, 2008
How can I fix error No. 6A80 on my Canon Pixma iP4700
Hi, That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer.
To reset follow this:
1. Turn off the printer.
2. Pressed simultaneously for 10 seconds on the following buttons:
3. Release the button "On / Off".
4. After a few seconds release the other buttons.
Thank you for using FixYa
Nov 15, 2010 | Canon iP4700 InkJet Photo Printer
Error code 6A80, won't print after changing ink cartridge. printhead is all the way to left. Tried moving it manually and turning off and unplugging printer.
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Jun 30, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Printer error 6A80 when printer is turned on. No paper jam noted. Tried unplugging, and turning off and on.
6A80
6a90
c000
6C10 feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective.
Troubles with purge pump and or purge tube plugged (clogged). Needs service tech.
Nov 24, 2009 | Canon PIXMA MP620 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I have a printer MP620, and get a error 6A80 need help.
Oct 22, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Canon PIXMA MP620 All-In-One InkJet Printer Logo
1,037 people viewed this question
old marine
old marine
