Question about Garden
Polaris Indy 500 carb float setttings
After cleaning carbs snowmobile still bogs when I shut the gas off and run it until it just about dies and then turn the gas on and the sled revs out good for a few minutes and then it bogs out again like it is to rich in fuel.seems like the float is not shutttin the fuel off .Yet when sed bowl is taken offf and the needle and seat are checked they shut the fuel off when you push the tab up to shut thefuel off manually it works fine. What should the float setting be?
2 Suggested Answers
  • 123 Answers
SOURCE: 97 polaris 500 sportsman 4x4 atv carburetor
If you have gone through the carburetor and your atv still won't rev it sounds like the exhaust lobe on the camshaft is going flat. They have an overhead camshaft in the 500 motor and the exhaust lobes seem to wear down if the oil is broken down (gas in oil) or if the wrong oil is used. Easy way to tell is to remove the 8 screws on valve cover and the spark plug. Then remove the 4 screws holding down the rocker arms. Once the rocker arms are removed you can see the camshaft, pull on the recoil rope to rotate engine until the lobes are facing upward. The two outer lobes are the intake lobes, and the center is the exhaust lobe. If the exhaust is worn, you will definitely be able to tell because it should be about the same height as the intake. Or if you don't feel comfortable doing that I would recommend a reputable repair shop. Hope this helps, and if you need more help let me know, Daniel.
Posted on Sep 30, 2011
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ... > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from
1995 Indy 500 EFI - won't start - Polaris Files > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
I have a 1989 polaris indy 500 was riding on the lake and after 24 miles it just quit. I have spark its getting gas and have comp. Please help!
I don't know where you live -- but up here in Alaska ( where it is very cold ) we have problems with water getting into the fuel of just about everything ( condensation from sitting )and the snowmobiles I have here I have to drain the carbs every now and then to drain out the little bit of water that finds its way to the carb bowl. ( just a thought ).
could also be a blocked/dirty jet in the carb, to cover all bases I would remove the bowl from the carburetor and spray down all parts with carb cleaner and then re-install and then try and run the sled. ( 9 times out of 10 the problems are carburetor related ).
Jan 22, 2011 | Polaris New Genuine Polaris Snowmobile...
I have a 1995 Polaris Indy 500. The engine floods out immediately. Once so bad yet a friend was going to borrow my machine it was running out of the exhaust pipe. If the plugs are dry, you get one pop...
this is caused by a stuck float in the carburetor. remove the carb from the machine, remove the float bowl from the carb, using carb cleaner - spray the components down and clean out any debris, make sure all parts move smooth and seals are clean, clear and not cracked,, re-assemble the unit and install back onto the sled. this will stop the constant flow of fuel.
have fun out in the snow --- ride on !!!
Jan 07, 2011 | Polaris New Genuine Polaris Snowmobile...
I reringed a polaris indy sport with a indy 500 engine in it, now the gas will shoot out of the spark plug holes. Is the fuel pump diaphram bad? Or are BOTH needels stuck? Or?????
Dec 10, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Feb 16, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500 efi snowmobile and I just put a new piston cylinder head on it and got ot to run but however it will run and take off accept when the throttle is wide open it dies and I have...
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
I have a 97 sportsman 500 . it starts right up and runs until you give it all the throttel then it bogs down like its not getting enough gas.
Bad gas..clogged jets in carb...very dirty air filter....clogged gas line or gas tank....stuck float in carb.
Oct 07, 2009 | Polaris ATV
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
