Question about Sharp AL 1631 Copier
Copier does not print copy
Copier makes a screeching sound. Paper feeds through. No lights come on to indicate toner or drum problems. Goes through start up check normally.
  • Anonymous Mar 15, 2014
    After pressing the copy button the copier tries to copy. The paper does not feed through.
    Problem Solver:
  • 5 Answers
This noise could be coming from the by-pass , because toner fall down pain in *** to take out. dale
Posted on Jan 23, 2009
My Sharp AL1530CS Copier is sick. I have a Sharp AL1530CS Copier. It has been great but has gotten sick. I replaced the AL110TD cartridge recently with a generic cartridge and toner leaked from it
Your machine is jamming (flashing p) because the toner that spilled has made the rollers slippery and they cant pull the paper out of the paper tray.
Apr 07, 2017 | Sharp Office Equipment & Supplies
When the "add toner" and "toner disposal" lindicators lit, I continued copying, until the indicator "memory overflow/data error indicator" lit - and no more copying was possible. Then I replaced the toner...
you have to reset the tonner counter and the drum ..and after that try again ...you will also have to empty the memory so to be able to take jobs ..Im not sure about the reseting procedure..but try to shut it down ..than unplug ...plug it back and press the power button and keep it pressed until it beeps ..will be about 15 seconds or so ..If this will not work ..take a look in the manual and see if they explain the exact procedure..
For other similar models you have to open the front door to get it into service mode..than from the service mode with the arrow select reset ..than one by one reset all ...toner counter ..drum ..and waste tank ..after that will do ..
Aug 20, 2010 | Panasonic Workio DP-4530 Copier
How to know if My copier need a new toner
For the toner you will have message that you need exchange it.
How many copies do you have? (press COPY key by the display and hold until the no of copies is displayed)
Where does the paper jams? ( on drum, on fixing roller, in cassete, in doc. feeder,...)
try to clean the pickup, feed and separation rollers
Feb 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
HI, MY XEROX 1045 COPIER has making ""clicking"" sound
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum.
Once you replace the drum, you need to reset the copier.
Nov 17, 2009 | Xerox Office Equipment & Supplies
I hear a screeching sound at the beginning, the paper rolls out smoothly but no copy is made
In most cases I would start with the drum/toner cartridge. Sounds like one of them is locked up! If you have a spare cartridge for either, try replacing it. Toner cartridges will lock up if the have been exposed to high heat conditions. Drum cartridges will flip the drum blade and usually give you a noise plus balck or very dirt copies, so I would look at the oner cartrige first. Remove it and see if you can turn any of the gears by hand. Good luck! Oh, and make sure you have either unit over a drop cloth or paper or something other than your nice white/tan carpet, cause they will both drop toner on you!
Oct 22, 2009 | Sharp AL 1631 Copier
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Problems copying with my Xerox 2515 copier
Paper goes on the bottom first. original goes in top next
Jul 31, 2009 | Ricoh Aficio 450 Copier
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Mar 16, 2009 | Sharp Office Equipment & Supplies
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
