Question about Gigabyte GK-OSMIUM Black Wired Aivia Osmium Mechanical Keyboard
Aivia osmium keyboard intermittently turns off & keyboard lights flash
When typing sometimes the letters are repeated 20+ times, the keyboard turns itself off and the keyboard lighting also flashes especially before it is likely to turn itself off.
Sony Vaio keyboard repeating letters
Keyboards to wear out, but are not expensive to replace. Multiple key strikes and sticking can be caused by spilling "stuff" into the keyboard, even crumbs will do it.
Oct 29, 2015 | Sony VAIO Computers & Internet
My keyboard typing multiple letters
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard\'s repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
If fails
Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean
If you are still feeling industrious, next you can tackle cleaning your mouse Of course, if cleaning your keyboard seems a truly undesirable task, you can always buy one for around $20.
Hope this helps.
Dec 31, 2012 | HP Computers & Internet
Can't type double letters can't backspace more
Push the shift key down until it beeps and it should unlock the keyboard and allow you to type normally.
Feb 08, 2010 | Dell 0Y3740 Keyboard
I have an HP Pavillion ze5300 laptop, and most of the time (15 out of every 20 minutes about) the "]" key keeps repeating. Sometime I can type if I am pressing the backspace key the entire time, but that...
It sounds like you need to replace the keyboard. Replacing the keyboard is not difficult or you can take it to a repair center. Parts can be ordered online from HP or aftermarket vendors.
Dec 09, 2009 | Saitek Executive PZ18AU Keyboard
Can't type some letters
sounds like either there is something stuck under keys ie (kids toys, food scraps, stuff) or keyboard is bad
Jul 20, 2009 | Logitech 9675020403 Keyboard
Laptop keyboard is typing numbers instead of letters
dude its so easy hehehe just press the function and insert key together and then its already ok!!!!!
a simple tnx is wat i need..:)
Jun 09, 2009 | ASUS 90-A4C1K1000 Keyboard
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Letters typing very slow and repeating
Sounds like your keyboard needs a clean and some new batteries.
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Open Questions:
Gigabyte GK-OSMIUM Black Wired Aivia Osmium Mechanical Keyboard Logo
89 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
