Sanyo Universal remote gxbm instruction manual
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
PaulTulsa
  • 14 Answers
SOURCE: sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Posted on Feb 17, 2008
andy4254
  • 226 Answers
SOURCE: Setting up a Philips Universal Remote for a Sanyo television
check out Philips support website for codes and instructions for that individual remote. most of their codes are the same for most of their universal remote controls. I suggest getting the original replacement remote for your TV because then you can easily just put batteries in the remote and not have to worry about programming and loosing codes. get the original at www.replacementremotes.com and at the top of the site just type in your model number of you TV and click search. They will set you up with your original remote.
Posted on Jun 11, 2008
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Posted on Dec 16, 2008
  • 4 Answers
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
Need codes and instructions to program Sanyo universal remote B21309 to a Philips Vcr/Dvd player.
Sanyo universal remote b21309 manual - logo - Tuars.com
ititoso.tuars.com/sanyo-universal-remote-b21309-manual/
Sanyo Universal Remote B21309 Please help find the manual for Question AboutSanyo Universal ... RMT-D153a RM-AX4000 Manual PDF instruction manual.
Sanyo Universal Remote RMT-U100 User's Guide ...
tv.manualsonline.com > ... > Sanyo Universal Remote
Sanyo RMT-U100 Universal Remote User Manual. Page 1. Page 2. Page 1 ... TheSanyo Universal Remote Control features large glow-in-. the-dark basic .
Nov 01, 2015 | Philips Televison & Video
Why do I now have to be very close to tv for remote to work?
There are a couple of different remote control technologies. Point to point Radio frequency, networked radio frequency and IrDA...or infrared diode.
Your Sanyo GXBM is an IrDA based remote. The diode is a lot like a lamp, only the signal it sends would be easier sensed by people as a change in temperature if it were strong enough.
Over time, the IrDA LED can degrade and will eventually fail. The transmitter in the remote can also fall out of spec over time, and the remote receiver in the TV lose its tune to the specific frequency that the remote broadcasts, making it harder to 'hear' he remote commands.
Other common issues for losing the range you had when it was new is clouding or scratching of either of the protective lenses on the TV and the remote.
i have included a direct replacement part for your GXBM
SANYO GXBC TV Remote Control
Sep 04, 2015 | Sanyo GXBM Remote Control
Will not turn on after disconnecting from DirectTV
Anon, try reprogramming Sanyo GXBM Remote Control. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Program Sanyo Universal Remote
How to Program Universal Remote https://electrohelponline.blogspot.ca/ Codes for Universal Remotes Welcome to Remote Central Universal Remote Control Reviews More
Mar 15, 2015 | Sanyo GXBM Remote Control
I need a setup manual for the hype 4-in-1 universal remote control along with codes to a sanyo lcd tv
Common set-up codes for Sanyo band TVs are; 0291,0299,0295,0297. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 07, 2013 | Universal Remote Control Televison & Video
How can i use a sanyo remote for this tv
Unless the sanyo remote is a universal remote control then there is no way they will match. With a universal remote control you follow the instructions on the user guide and select the appropriate code from the list which comes with the remote . Then program the device following the instructions in the manual and your device will work.
Hope this solution has been helpful?
Oct 24, 2010 | RCA TruFlat 27F520T 27" TV
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Manual Controls Insufficient
What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
Jun 11, 2007 | Sanyo DS20930 20" TV
Televison & Video Logo
387 people viewed this question
Top Televison & Video Experts
Electro Med Services...
