Question about Alpine PDX-F4 Car Amp
How to set alpine pdx f4 crossover to run alpine spr 68 speakers
3 Suggested Answers
  • 9 Answers
SOURCE: Alpine PDX-1.1000 to a 10 "Alpine SWX-1043D
straight up. Since it has the power saving technology where it gives out the same power at 2 ohm and 4 ohm loads then u dont have to bridge it and since its a single speaker you dont have to bridge it and since it is a mono block oyu dont have to bridge it. just wire + to + and - to -.
Posted on Jun 02, 2009
  • 8 Answers
SOURCE: what do i set my crossovers to i have an alpine
Set the two switches filter to: off. You do no need filtering your speakers as they are full range ones.
Posted on Aug 19, 2011
Spr-69 crackling
It may be a bad voice coil. It would make that type noise. If the cone isn't cracked its the coil.
Jan 25, 2014 | Alpine Type-R SPR-69 Car speaker - 100...
What do i set my crossovers to i have an alpine pdx-4.100. and im useing it in sterio to power 4 2 way speakers
Aug 15, 2011 | Alpine PDX-4.100 Car Audio Amplifier
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
I just install my new setup ,i have 1 pdx f4 ,1 pdx m12 and 2 sub 10''type r and my pproblems is when i put a song the pdx f4 lights become red and my mid and tweeter cut ...
Disconnect all speaker leads from the PDXf4 - test. If the amp turns on and says on ok - then turn off, and attach one speaker lead at a time until it turns off. When it does check that speaker and the speaker wire to see if it is blown, shorted out etc.
Feb 06, 2011 | Alpine PDX-F4 Car Amp
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
PDX-1.600 no sound from speakers
check your coil wires on the back of the sub
Apr 11, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
PDX 4.100 In Protect Mode..
According to the manual, the issue could be:
  • Internal issue with the amp circuitry.
  • A short on the speaker output(s).
  • Power source voltage is too high (aka above 14.5V).
  • Overheating.
The easiest thing to do is to try removing the connections to the speakers at the amp and see if the issue disappears after each set has been disconnected. Keep removing wires until both LEDs stay blue.
Mar 15, 2008 | Alpine PDX-4.100 Car Audio Amplifier
Alpine PDX-F4 Car Amp Logo
42 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
