Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
3-d images Hi, my Hitachi hdtv is having quite a problem right now. The colors separate instead of merging together. I believe it's a convergence piece but I'm not sure. It basically looks like it's 3-d, instead of having solid colors put together. Anyways, I'm trying to find a tv repair guy in my area but I can't, so I found this website and hopefully yall can help me. Thanks
  • Anonymous Jan 23, 2009
    My TV does the same thing
  • gabredberg Feb 04, 2009
    Same Tv Same problem! PLEASE HELP I love this TV :)
  • 42 Answers
It sounds like your convergence ic's are messing up
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
Posted on Feb 10, 2009
I have a RCA 52inch hdtv that has three color lines red green and blue at the top of the screen together and then they separate. It turns itself on and off. And the images on the screen appears to be three...
Go to Menu then setup ,Do you see Convergence, If not then you have a Blowed Fuse on the Deflection Board FL231. Deflection board will be the bottom lefthand side with FBT flyback transfomer on it and on the right hand side of FBT is 3 Fuses in a roll but they do not look like Fuses they will be small rectrangler looking caps but are Fuses it will be the one in the Middle. .06amps. If you have anymore question let me know . Thank You
Jun 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My t.v.focus is like double vision and the color is not right.
convergence failure that tv has 3 CRTs-cathode ray tube- and it has a circuit that keeps each picture projected from the tubes aligned together called convergence. so if you have a picture that has 3 pictures of the same image in red green and blue then it is defintely a convergence failure. the part numbers of the parts causing the failure are STK394-160 and there also can be some burnt resistors in the same circuit.
Jan 06, 2011 | Hitachi 57F500 57" Rear Projection...
The red and green is separated and there is a double image.
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Hitachi 57F500 57" Rear Projection...
The colors are separated. Images are blurry and
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Sony KP-51WS500 51" Rear Projection...
Red shadow on TV Screen Hitachi HDTV
Your convergence is bad. You need to have convergence amplifiers changed.
Apr 21, 2009 | Hitachi 51F59 51" HDTV Projection...
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 53UWX10BA separated colors.
replace the convergence ICs you can get replacement ICs at the following link with free installation instructions. Use two STK392-150 ICs they are good durable ICs for your model,
Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Color distortion and arched picture
Your TV most likely has one of two possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
3 images in the primary colors
Your convergence amp ICs are bad they need to be replaced.
Feb 16, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Everything looks like a 3-D movie!
Replace convergence IC's IK04 = STK392-150 and IK05 = STK392-110. Also check resistors RK42,RK46,RK50,RK54,RK58,RK62 for burnt/discolored.
Aug 20, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
