Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lens popped out and says i need to restart it?!
My brother picked me up and my camera fell out of my pocket and hit the floor. the lens popped out and it won't go back inside. the screen reads that i need to restart it, but i don't know how to restart? help?
  • 489 Answers
Hi
What you are seeing is a generic stuck lens error message, it just means to turn the camera off and then back on again in hopes that the lens will become un-stuck... It won't.
Your lens needs to be repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from.....
Darntoothysam com
Posted on Sep 22, 2008
I have a cam model ixus 75, my camera charger is missing any where, can it charge with data cable
Posted on Mar 20, 2008
    Problem Solver:
  • 40 Answers
Cameras & hard floors are never a good combo. Im no help, except to say that if it were mine, I'd email the camera manufacture that question, and I'm sure they'll provide some useful info.
Posted on Jun 24, 2007
SOURCE:
I was using my camera on a tripod, and then it broke, and my camera hit the counter, then fell onto the hard floor. I thought it was okay, and i picked it up. When I went to take more pictures, it wasn't...
The kit lens that came with your camera is quite cheap. Around £50.
Look for a replacement as it sounds like it is mis-alligned and the focus motor has broken.
You can then use the broken lens to tinker with.
Mar 05, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I need your help please, I fell with my Nikon camera, the body still works, but the 55-200mm lens does not work again, for seeing through the viewfinder the image is dark. The lens does not hit with...
Okay if you have luck all that's happened is you have jarred the lens contact between the camera body and lens. Make sure the camera is turned off then remove the lens and clean the gold contacts on both the lens and camera body. Remove the battery, install the lens and replace the battery, turn the camera on. If it still doesn't work shut the camera off and try another lens and see if it work properly this will tell you if it's the camera at fault or the lens. Switch lenses between known working cameras. I'm sure you will find the lens has come loose. I only once had a lens come apart from a jar (not impact) and it actual popped apart in pieces.
Dec 10, 2010 | Nikon D60 Digital Camera with 18-55mm +...
Camera fell on floor, now pictures out of focus
That's because the internal focus servomotors are out of place and can't turn the focus ring. I'm sorry but these components are located inside the lens assembly and this is not by any means an user serviceable part. It's composed of tiny servomotors, small coils and plastic parts that can get out of possition or decalibrated if the lens assembly gets opened.
A thing to try would be to hold the camera with it's lens barrel opened in one hand and hit it (gently yet still firmly) against the other hand. There are some small chances that this will bring the internal focus ring to it's former alligment. Other then this, only a service center can fix the camera, but it could turn out to be an expensive repair.
I'm sorry for having to bring the bad news.
Bogdan
Jul 09, 2009 | HP Photosmart M537 Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Camera fell off TV tray; lens bent and won't retract
i had the same problem. just force the lens back into place. I did that and it worked perfectly!
May 15, 2008 | HP Photosmart R927 Digital Camera
Lens spring/s
I had teh same question, I'm trying to repair mine atteh moment and there is only one spring. still trying to get teh lens back together propoerly, managed to rip a cable track so have to get another anyway... spewing..
Sep 20, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera fell on floor and lens popped out
http://www.lensbabies.com/index.php?r=GSLBGeneral&gclid=CJSbjPWUrI0CFQqgYgodlz7D1Q chek site you will find diagram
Jul 16, 2007 | Olympus C-3000 Zoom Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
