Question about IBM ThinkPad T40 2373 Notebook
How to fix Error 0189
I have problem with My ThinkPad T40 2373 - 72A, error 0189 appear when it's start to boot. The only solution that I find so far is replace the systemboard. But I wonder if there any other solution of this problem.
This worked for me on a R40 with the 0189 issue.
When the message pops up, hit escape to continue.
1. Download the IBM Hardware Maintenance Disk and create a floppy. The filename for version 1.75 is i7tm23us.exe. I found it at ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/i7tm23us.exe
2. If you do not have a floppy drive on your laptop, then use nero to create a bootable CD from the files and boot sector of the floppy disk.
3. Boot your laptop from the CD, then choose the Assign UUID option.
This should do the trick for you.
Posted on Jan 18, 2009
How to fix error 2100: hdd0
The ThinkPad system may experience a bluescreen that may only appear for a very short time, followed by a reboot. During POST, the system will display a POST 2100 error code indicating the drive cannot be initialized. The machine will not boot into the operating system.
NOTE: Powering the system fully off and then on again after 20-30 seconds will usually clear the error, but a warm reboot will not.
IT have personally experienced this issue twice so far, & Lenovo posted an advisory on this in July.
If you have encounter this issue since getting your T440 notebook, it's highly recommended to update your SSD to this new firmware.
The firmware updater is windows based, & is non-destructive (does not affect existing data) so it's easy to update.
To be absolutely safe though, it's recommended to back up your essential data before installing this firmware update.
ThinkPad may bluescreen and reboot to POST error 2100 Lenovo Support US
Also recommended is to use CCleaner registry cleaner which solves the problem temporarily.
CCleaner PC Optimization and Cleaning Free Download
Feb 13, 2015 | Computers & Internet
Error 0189 invalid rfid configuration information area
You have a system board error. The BIOS is corrupt and there is nothing the layman can do except replace the motherboard.
Oct 03, 2012 | IBM ThinkPad T20 Notebook
Media disconnected error on ibm r52 thinkpad
Change the hard drive, it is clear this is a hardware issue.
Jul 27, 2012 | IBM ThinkPad R52 Notebook
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save mode...it brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Jun 14, 2010 | IBM ThinkPad R51 Notebook
After pressing access imb the following error come up 0271,0187,091 I've went into default setting and the same problems acord what can i do to resolve the problems? ibm thinkpad x41
my name is frank and i have this problem with my IBM thinkpad T40
which is every time i boot the laptop then Error 0271 appears what should i do to prevent this error thanks
Apr 20, 2009 | IBM ThinkPad X41 Tablet PC
Thinkpad T30 Error 1802 from Verizon modem..Now won't boot past error message even without modem plugged in. Help
The 1802 error is ussually caused by an "unsupported" wireless card being installed. check out this site for a fix that has worked for me on a couple Thinkpads (including the one I'm writing this message on) to allow unsopported wifi cards to work.
http://www.command-tab.com/2006/02/26/thinkpad-1802-error-fix/
Mar 12, 2009 | IBM Thinkpad T30 Notebook
IBM ThinkPad T40 2373 PC Notebook error 1802: unauthorized netword card isplugged in my laptop cannot boot because of this probs
This is ussually caused by an unsupported WiFi card being installed. You can correct this problem by using a quick BIOS hack... (If you are getting the 1802 error)
Go to this site for the fix: http://www.command-tab.com/2006/02/26/thinkpad-1802-error-fix/
Jan 26, 2009 | IBM ThinkPad T40 2373 Notebook
Error code 176 appears at boot up
Have you set a password in the BIOS, this is usally a tampering error code
Nov 24, 2008 | IBM ThinkPad T30 2366 Notebook
ThinkPad T22 will not boot to windows
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Jul 07, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T40 2373 Notebook Logo
3,489 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
