Question about Euro-Pro Upright Steam Mop - Metallic Lavender
Red light to bionaire steam mop stays on
Plug in and the red light come on, checked water and pad. unplunged and repluged
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Posted on Oct 10, 2009
heatman101
  • 43501 Answers
SOURCE: My shark steam mop will not start steaming. Are
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
f
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: My steam mop all of a sudden stop steaming. The
heatman101
jr
heatman101
  • 43501 Answers
SOURCE: steam mop does not operate
heatman101
f
Posted on Sep 29, 2010
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
Light keeps flashing on top of canister of my Hoover Wind Tunnel but I emptied and cleaned it well. It sounds right when I turn it on then it goes into this sound like something is stuck but there...
sounds like a possible plug ,then when you first start it up the plug gets stuck a gain.
try taking hose off the unit and running water through hose .if water flows good ,check and see if lid is secure when closed.
Jul 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
Get no steam, light on so there is electricity, water in holder Pad correctly in place Model #S3101Q. Have tried plugging and unplugging. Filled the receptacle, changed pads. No steam
heatman101..
Oct 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Makes steam. Leaks where pad goes into pad attachment. Pad doesn't get hot steam...just water but the pad doesn't really get wet but the floor does.
heatman101
Oct 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have had my shark steam cleaner for 6 months now and I love it, but I have hit a snag. I have not useed it for a cople weeks and when I plugged it in today - no steam. It seems to heat up, but there is...
No, these things don't last long...send it back...
heatman101
Aug 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Upright Steam Mop - Metallic Lavender Logo
98 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
