Question about MSI 865PE Neo2-V Motherboard
Fan running blank screen cant get into bios.was ok now this
I was using vista p4 pro ,msi motherboard .
  • 85 Answers
Can you feel the hdd vibrating when you power up or not
Posted on Jan 18, 2009
Computer will not boot. It makes a few sounds and fans run
Was it working prop in first place, shutting down properly when last used?
What prog are u running. XP/Vista?
Nov 01, 2009 | MSI PM8M-V Socket...
Ram upgrade issue msi 845 pro motherboard
you should check bios for the ram settings, voltage and speed, they will be printed on the package the ram came in.
also, you don't want to mix ram up, they will run at the slowest ones speed.
also, most ram is used in pairs (2 at a time) using the 3, depending on the motherboard will give you errors.
try entering the bios on boot, and set the ram setting properly. you should see something that flashes on boot, like press f8 or del for bios. change your ram settings, save and exit. type back with your motherboard and ram model numbers if this solution did not work.
Jun 25, 2009 | MSI 845 PRO Motherboard
Lets not jump to conclusions. Personally I feel that if give it a thorough cleanup without removing the Processor from under the heat sink, clean all the contact points, specially the power connection to your HDD(if its SATA it will make faster noises) and this could be due corrupted OS files too, but if the noise in the HDD persists, then its advisable to replace it if still under warranty, else use any working HDD and check to see if the same thing happens again. Don;t forget to repair your OS first. Also do checkdisk yiur HDD partitions particularly the one where the OS is installed and if it throws uo any bad sectors then the first thing to do is install the OS on a different partion. If it behaves properly then you have to make a desicion regarding repairing/replacing the HDD.....sodeep
Mar 31, 2009 | Acer (ACERMOTHERBOARD)
Hard time getting new build to boot...
sounds to me like you either have a conflict of hardware or your os windows xp wasn't meant for your hardware some manufacturers design there products now to be vista only so read you manuals and make sure of that then try reloading xp but with bare essntials to run a pc that is
Mar 15, 2009 | Computers & Internet
Vista Home Premium locks up on a load
How long do you wait before you determine it is locked up? Vista uses minimum graphics to facilitate a faster install. It may seem like nothing is going on when Vista is loading in the background. If it is locking up try a reinstall. Are you upgrading or going a new install?
Dec 30, 2008 | MSI K8N Neo3 Motherboard
MY msi 7082 cant read HDD 40GB and above whY>?
Your board specifications are here - http://www.msicomputer.com/product/p_spec.asp?model=661FM3-L&class=mb
This sounds like a memory timing issue based on the caution from the MSI page. There is no reason the board itself should have a problem with that size hard drive. Have you reset the bios to factory default and tried the various compatibility settings available in the bios?
Dec 26, 2008 | MSI 7082-010 (661FM3-V) P4 LGA775/SiS...
Bei Motherboard MSI K7T266 Pro 2 kein Audiosignal (Ac97 im Bios enabled)
ok what are u trying to do diable that or remove it from the log on screen i can help you please let me know more ok thankyou
v/r mike
Aug 04, 2008 | Computers & Internet
Problem with installing video/audio drivers..
i don't have audio driver of intel p4 processor.how can i download it?any website for that?
Dec 03, 2007 | Intel 845GE Motherboard
Msi 654e max atx mother board
If your manual states a max of 2.2GHZ then, take it as that, when your board was made the bios and bus speeds would be set at the maximum to run a 2.2GHZ, not a 3GHZ, also the heat sink and fan may not be enough to cool the processor. The only way that a 3GHZ would run was if you updated the bios and personally i would not recommend it. You would be better advised updating the board and processor as a package ot fitting more memory if the pc is not used for gaming or high end video editing.
Apr 19, 2007 | MSI 645E Max Motherboard
MSI 865PE Neo2-V Motherboard Logo
80 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
