Question about Proscan Televison & Video
Proscan pled2402a remote code to comcast
Cant program remote from comcast to proscan 24 tv
SOURCE: Remote Code
The code 11178 worked for us for our Comcast remote.
Lauren
Posted on Feb 15, 2009
  • 3 Answers
SOURCE: I need the dynex tv code for a comcast remote control
Try 10463, or the Emerson tv code.
Posted on Apr 09, 2009
SOURCE: I NEED A CODE FOR A COMCAST REMOTE FOR A NEW HCT TV CAN YOU HELP?
press tv on your remote then sutup till it blinks 2 times the press 991 the tv key will blink twice.then press ch+ or ch- till the tv turns off.it will scan all remote codes once your tv turns off then press setup and the the remote will lock the code.
Posted on May 03, 2009
h_caines
  • 8 Answers
SOURCE: Comcast Remote Control Code
10150 worked for my mitsubishi wd65737
Posted on Jun 17, 2009
dvinnedge
  • 35 Answers
SOURCE: how to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
Posted on Jul 07, 2009
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
I just bought a new 40" proscan tv and my comcast remote won't program to it. I've tried every code.
that is not unusual as comcast is not a universal remote . non compatible units
Dec 20, 2015 | Proscan Televison & Video
Programming comcast remote
the codes for the remote to access a Proscan TV are as follows: 11447, 10047, or 11347. I assume you know how to get into the remotes coding mode, but if you don't Here is how you go about it press setup, then press and hold the TV button until the light flashes then input one of the code sets, then if you get a confirming flash hit the power button if the TV turns off your golden if it didn't repeat the cycle with the next set of numbers I gave you. if after you have tried all three numbers you still can't get the TV to react to the remote you will need to call 1-800-COMCAST and speak to someone on their technical staff.
Dec 08, 2009 | Proscan 32LC30S60 LCD TV
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
Have 40 inch Proscan TV. Am trying to program my Verizon (FIOS Service) Remote to recognize the TV. None of the numbers furnished by Verizon work. Proscan gave me some weird numbers that do not work...
You mostly have to go through all the numbers to find one that works. Sometimes, with an off brand TV I have the best plasma i've ever owned right now. It's not a fancy brand name and the remote ( Comcast ) wont work for it. The comcast guy said that it would not work with my TV. Hope ite helps. You may not be able to pair the two at all.
Jul 17, 2009 | Proscan 42LA30H 42 in. LCD Television
Remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
May 23, 2009 | Samsung DVD-HD845 DVD Player
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote Code
Lauren
Jan 13, 2008 | Proscan 26LA30Q 26 in. LCD Television
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
168 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
