Question about Vacuums
Cord rewind The power cord is jammed and won't go in or out. I can't find a way to get the cover off to have a look at it. Any suggestions please? Power cord jammed won't go in or out. Can comeone tell me how to undo the casing to get to the power cord?
  • 2 more comments
  • Str0hler Jan 18, 2009
    cord is caught over some kind of protector near wheel. Case has to come off but how?
    Have tried this, but cord looping over a protector. Case has to come off, but how.
    Sorry everyone, think I've accepted when I still have a problem!!!
    Have tried this with no success, well and truely jammed
    President:
  • 2,110 Answers
Which model do you have..
Posted on Jan 18, 2009
    Genius:
  • 2,920 Answers
Push the cord part way in and then give it a tug...it should un bind itself that way
  • 10,515 Answers
I just had this exact problem. There are 4 easy to find screws under the bag container lid. The 5th impossible-to-find screw is located under the large, gray cord release button. If you can pop that button off, the 5th screw is accessible and the whole top comes right off.
I am going to write a scathing letter to Hoover. There is no reason to make it so impossible to remove the canister top. A miniscule amount of ink in the user's manual showing an exploded view would have save my needed to break my S1361 to fix the stuck cord problem. I otherwise have really liked this cheerful, but useful product. I only wish someone else had posted this information so I wouldn't have had to use brute force to open mine. :-(
Good luck
Thanks.
  • taran_2005
    taran_2005 Jan 18, 2009
    Hey
    a diagram too - blog :0
    http://reverb.madstatic.com/blog/2009/01...
    I hope it wld help u as well...
    Take care and do rate this solution :)...
  • taran_2005
    I had a similar problem with Hoover Sensory model. The design appears to be very similar to the one described here : two buttons, difficult to remove due to three plastic tabs in each, 4 screws and so on. Thanks to the earlier solutions, I was able to take it apart, fix, re-assemble and test in 50 mins! Great guys, thanks a lot.
    Couple of notices I made : I hate these new household machines which are purposefully build with aforementioned plastic tabs so that you break it easily if/when you try to fix it yourself and therefore you'd be using Hoover qualified (tm) service instead! I bet that those Hoover repair-men have a special three-point tool to extract those two buttons (power and cord rewind).
    Anyway, you can use simply three thin blade dining knifes to perform the same operation. First, push the knifes in on three sides so that all tabs snap off. Then pull the button off. This is the difficult part. After removing the buttons, remove the four very visible and easy open screws. Lift the inner housing lid off with the filter on top of it. Carefully lift the electronics/electric part on a circuit board, there's enough loose wire to very carefully and gently lift it up and aside. Now you have clear view of the rewind wheel under it; examine it, for example, my cord had not jumped off the wheel, but the wheel had jumped off-axis somehow. Restore the normality (for the rewind wheel) and pull out all the cord (maybe you could consider never rewinding it again?). Play around with rewind mechanics, just to see how it works. Put the circuit board part back on, gently (there's loose wire, but not too much). Study the alignment of the circuit board. You can put your finger through the power cord opening in the back side and pull the plastic (don't you just hate the word :)) part closer so that the wheel underneath, the circuit board and the housing lid all align nicely. Spend some time here, making sure everything still works (carefully, remember electricity is dangerous too!) test the vacuum operation. Finally align the housing lid and screw it back on. The white stick in the power button DOES NOT push the red button inside but the it is used to screw to variable resistor instead (took me 5 mins to figure this :)). Pop the buttons bak in, it is very easy this way.
    Test everything works still.
    Never rewind again.
    Never ever buy Hoover again:) (just kidding, it wasn't that bad experience)
    This saved my cleaning day and a stupid call and service for my Hoover. And now I can fix it myself. How cool is that :)
    Do rate this thread........
    Genius:
  • 1,913 Answers
Put some oil then pullpower code shaking it.
if not then u have to unscrew some panel.
How to rewind the power cord assemble?
The only way to rewind the cord assembly is to take the cord real out of the vacuum and rewind it and put it back in. There is no easy way to do it
Apr 29, 2014 | Miele S514 Solaris Electro Plus Vacuum
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Cord won't retract or pull out
No, but we have a great network of warranty repair centers. You can find one near you at this link:
Jul 03, 2013 | Bissell PowerGroom Helix Rewind Bagless...
Power cord will not come out
There is probably a crossed cord in the rewinder. I am not sure but if you can get into the rewinder you can free up the cord it should go, hope this helps. Chris
Feb 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Power cord won't retract on anaerus 5500 vacuum cleaner
What you can do is take out the six hex screws on the bottom of the machine while on it's back. When all the screws are out, flip the machine back over, making sure you don't lose any of the screws. From there, open the bag cover and leave it open. Remove the cord release button. (The big rectangular button near the rear of the machine. Usually a firm pull up will get that thing out without incident.) Grasp the handle with one hand and hold the machine steady with the other. With a firm pull, pull upwards. This should seperate the chassis from the main cover.
With the machine guts exposed, place the main cover on the side for now. Now, this next part you can do one of two ways. You can either leave the cordwinder wires attached, (there's only 2 connected wires to the cordwinder, the white and black. Black is on the inside prong while the white is on the outside) or you can take the wires off. I find it easier to disconnect the wires.
Now, remove the cordwinder from it's place, making sure you take note of how the cordwinder rests in the groove from the motor. From there you can rewind your cord fully. Once this is complete, continue winding the cord while holding the cord in place. Take note of the spring. Make sure you are winding in the direction that is TIGHTENING the spring. Make sure you don't overtighten as the center plastic piece will surely snap due to the overtension. This may take a few tries, but be patient. Once you have met your estimated tension needed, replace the cordwinder, put the cover back on WITHOUT SCREWING IT BACK IN PLACE and replace the cord rewind button.
Replace the large cord release button and pull your cord out at least halfway. Hit your Cord rewind button. If your cord rewinds fully, congratulations, you got it in one try. Replace the screws and you are finished. If not, re-open the machine and continue rewinding the cord in the direction that TIGHTENS the spring with emphasis on overtightening. Once you break that center plastic prong, you need to buy a new cordwinder, so emphasize patience. If you're getting frustrated, go take a break and come back. Repeat until the cord winds fully, replace all the screws and you are finished.
Apr 20, 2008 | Electrolux Vacuums
Power cord retrieval
Depending on which model you have, take the bag door or lid off by pushing it back and it will unhook and come off, there are 4 screws that hold the cover on over the where the cord rewind button is, take that cover off and you can get to the cord reel.
Feb 12, 2008 | Kenmore 23313 Whispertone Bagged Canister...
The cord won't rewind anymore.
all these rewinds are a pain! the rewind mechanism is a spring-loaded coil. fault is possibly that the cable is jammed and you may be able to free it by gently tugging and releasing. otherwise there is a problem with the spring and that is not worthwhile repairting
Mar 26, 2007 | Bosch BSG81313UC Premium Bagged Canister...
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
