Question about Hotpoint RGA520 Gas Kitchen Range
Oven will not lite
Hi, I just moved to this apartment and I´m trying to lite the oven (which belongs to the apartment owner). I turn the dial to 350 and nothing happens. I used the stove and it works fine, I have fire in all the four of them. Thanks a lot for your attention, Best regards, Ariosto
  • Anonymous Jan 06, 2008
    i need to take the bottom of the oven out to light the pilot but we dont have the instruction book, does anyone know how to do this?
    Problem Solver:
  • 12 Answers
This happened with my self cleaning gas range. The burners worked fine. I checked for a leak. Turns out the igniter needed to be replaced. The landlady had a warranty from Circuit City so the repairman replaced the part. Sounds like you may me in the same boat. I sure was happy to have my oven back! : )
Posted on May 14, 2008
Might be a electric start oven check to see if it needs to be plugged.
in .
If the ignition sparker or the relay is fried( shorted) out there not to difficult to replace..
But seeing that you rent I would get the manger of the apartment to do it.
Posted on May 05, 2008
  • 35 Answers
You would want to make sure and check your pilot light.
Posted on Jun 25, 2007
  • kelsey johnson Jun 30, 2007
    try holding the oven thermostat knob down while simultaneously lighting the oven.continue holding down for at least a minute or at least until pilot remains lit.
New stove with no owners manuel
whut is the brand and model number, number will be usually on frame u can see by pulling out lower drawer, if i have that number i can search online or go to the manufactures/makers website most have downloadable or printable manuals let me know if this helps
Feb 14, 2010 | Ovens
When i turn oven nob no gas will go to oven burner to lite oven. took apart oven hose connections and did not smell gas. thanks
Hi, The problem is with the ignitor 9 out of 10 cases. On oven's with hot surface ignition the ignitor act's like a resistor, (not litrally, just an example to help) when it is good and glowing almost white hot, it will only then open the gas valve to lite the burner. (don't let the fact that it is glowing to a lesser degree fool you as often it does with do-it- yourselfers or even technician's not familiar with them) A common ignitor for Maytag ovens is 77001258 and usually retail at $40-$50. Check with your local part supplier or any number of on-line vendors using your model & serial number. Hope this help's, if so please take a second and rate the solution I provided for you here at fixya...and spread the word. Thank you and good luck. macmarkus :)
Dec 07, 2009 | Magic Chef Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
I need to find a copy of the manual for a GE profile model number jvm290bv001 microwave/convection oven... my apartment came with only that for an oven an now i cant seem to get the convection oven...
You can download GE owner's manuals and installation instructions here.
May 22, 2009 | Microwave Ovens
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to david.stevens@vibanalysis.co.uk and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Apr 27, 2008 | New World E70DOa Electric Double Oven
My oven wont come on
try this if one of the dials is pushed in turn the other around till it pops out
Feb 13, 2008 | Ovens
Hotpoint RGA520 Gas Kitchen Range Logo
223 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
