Question about Canon PIXMA Office Equipment & Supplies
Canon MX360 U052 Error - no apparent way to remove printer head; appears to be unlike other Canon models with a easily removable print head
U052 Error related to 'cleaning printer head'. Most other Canon models have bar that you lift once the print cartridge is removed. Lifting the bar allows easy removal of print head. This model does not have a locking bar. It is not apparent how to remove the existing head without pulling off the chassis. Don't think you should have to do that...
SOURCE: Can anyone tell me how to remove the print head?
Take out the cartridges first, then the printhead will come out easily. Grab it at the top, and gently Pull out. That'll do it good Luck!!
Posted on May 31, 2007
SOURCE: Canon Pixma MP610 CARTRIDGE PROBLEM
HI. Try holding the reset button for 6 seconds to overide the error. This may dissable the chip so it won't report but will allow you to keep printing. Simply check the ink tanks visually.
Refilling will give the same error too, again dissable the error.
Cheers Bob Monk (ink manufacturer magink@froggy.com.au)
Posted on Jun 02, 2008
SOURCE: Apparently, my printer (Canon i850)
follow the instructions in this website:
http://www.fixyourownprinter.com/forums/inkjet/53369
Posted on Aug 27, 2008
yooperbud
  • 8637 Answers
SOURCE: i think i inserted the
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
SOURCE: Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Posted on Apr 09, 2009
What is the corrective action for error U052?
Search "u052 error canon" and choose the hits to open.
Jul 08, 2015 | Canon MG5350 Wireless PIXMA Inkjet...
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
U052
To try and resolve the U052 error on your PIXMA MP550, please remove the ink tanks and print head from the printer, then reseat them. If you still experience the same issue, please turn off the printer, unplug the power cord from the back and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the issue is still unresolved, unfortunately, the printer will require servicing to resolve the issue.
You can contact Cannon here: Canon Contact Us
This information originally from: My printer Canon MP530 stopped working with an Canon Forum (also has a walk through for removing the printer head and ink cartridges.)
Just so you know, the 530 and 550 are the same machine, except the 550 has a few small improvements.
Mar 31, 2014 | ErrorExpert
Canon MP660 U052 Error
Remove and reinstall your Printer Cartridges. Else, you will need to take your printer to a Canon Service Center to have them replace your faulty Print Head / Temperature Sensor that is causing the U052 Error.
Oct 24, 2011 | Office Equipment & Supplies
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP600 printer, error msg. U052 Cleaning the printer head doesn't help. Replacing with new (full) cartridges doesn't help. The only one thing, that helps now, is to disconnect the printer from power...
Description
Reseat the Print Head to resolve the U051 / U052 error.
Solution
Errors displayed on the printer's LCD screen:
  • U051 Print head is not installed. Install the print head.
  • U052 The type of print head is incorrect. Install the correct print head.
Reseat the Print Head:
  1. Make sure that the power is turned on, and open the Paper Output Tray gently
  2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
  3. Remove all the Ink Tanks in the following manner.
    1. Push the tab (B) and lift the ink tank to remove.
    2. Do not touch the Print Head Lock Lever (C) while removing the ink tanks.
  4. Once the ink tanks have been removed, raise the print head lock lever.
  5. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
    *Before proceeding to next step, check the carriage area for packing material, torn paper, etc. and remove if found
  6. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
  7. Insert ink tanks into the print head.
    1. Insert the front end of ink tank into the Print Head at a slant. Make sure that the position of the ink tank matches the label.
    2. Press the mark (Push) on the ink tank until the ink tank snaps firmly into place.
      Make sure that the ink lamp lights up red.
  8. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    Note: When the next printing begins, the print head cleaning will begin automatically.
If you have reseated the ink tanks and print head and the error still appears, our industry-leading support team is available to help you Monday through Friday from 10 AM to 10PM EST. You can contact our technical support experts by phone or email:
Call 1-800-OK-CANON (1-800-652-2666)
May 06, 2017 | Canon PIXMA MP600 all-In-One InkJet...
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Mar 01, 2010 | Canon MP610 Photo All-In-One Printer
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Jul 26, 2008 | Office Equipment & Supplies
46 people viewed this question
old marine
old marine
