Question about Foxconn Computers & Internet
Does my board support my GFX card?
I have bought this card but I am not sure if it will run on my motherboard.. MSI GT 620 1024MB GDDR3 Man Pt# N620GT-MD1GD3/LP When I tried to install it there was no post display and only beeps so I took it out and went back to using the onboard GFX... Please can somebody help me as the foxconn site doesnt seem to work properly whenever i try to access the technical help or customer support.....
  • 231 Answers
SOURCE: no beep codes no post no video
Hi, sounds like a RAM problem, if you have 2 RAM sticks, pull one out and put the second one in DIMM one, try that then try 1st one in DIMM 1, next test is to try a friends RAM. IF all fails go back to where you purchased the board and have them test it under warranty. Regards mistyman
Posted on Sep 13, 2007
SOURCE: no post no beep no video
it could be because of your processor.. i have the same problem. At this point, i think it is because of the processor.
Posted on Oct 09, 2007
SOURCE: Foxconn 946GZ7MA-8KRS2H
Thanks for the above, though it was not the solution it helped me to understand what was wrong.
For some reason, the BIOS that the board shipped with was causing all of the above problems.  I stripped and re-built the PC a few times with the same results, until I eventually found a BIOS update from the Foxconn site.  I installed it and *most* of the problems went away.  It even let me install my Nvidia 8500gt pci-e card which worked straight away.  It seems strange that the original bios version would not support my pci-e card...this is not something I've come across before.
The only residual problem I have is that when I shut down the computer, it reboots itself.  This happens every time and so I am going to try and fiddle with the power options to try and stop it happening.  Again, this seems to be something the BIOS still does of its own accord.
Thanks again,
Nick Lyons
London, UK.
Posted on Oct 10, 2007
  • 34 Answers
SOURCE: Display Problems
enable your onboard graphics and plug your monitor into the onboard. start up your pc and install any needed drivers for the secondary graphics card. right click on your desktop and go to your display properties you should see a faded out screen that has a 2 and a lit screen that has a 1 right click on the faded screen and check enabled then move your monitor cable over to the new vid card right click on the lit 1 and disable it making 2 your primary.
Posted on Aug 20, 2008
  • 191 Answers
SOURCE: Computer Does not Boot correctly, Monitor is Black.
try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
Posted on Sep 27, 2008
Is my Mobo compatible with this GFX card???
Hello here is your mainboards homepage:
Download the manual.
You will need adobe reader to read the content.
You might have to disable the onboard graphic in the bios when you install the graphic card.
Disable the driver for the onboard graphic or uninstall it before you install the new driver because the driver does not fit the new graphic card.
It will probably also help to upgrade the bios to the latest version
just make sure it`s the right mainboard.
Flashing the bios with the wrong one will destroy the mainboard !!!!!
If you are in doubt upgrading the bios let a expert do this for you.
You can download the latest driver here at nvidia:
Just remember to select the right graphic card and your windows system.
Good luck
Dec 30, 2012 | Foxconn Computers & Internet
I got the msi p965 platinum board today secondhand i installed it and double checked all connections. i installed my 9500 gt gfx card and pluged everything in and swithed on there is powere permanently but...
Boot into your bios when you are first turning on the computer(Press Del while the Press DEL to enter SETUP message displays on screen after powering on the computer.) and look and see if you have "only use on-board graphics" set. Sometimes you have to click the arrow and choose"use graphics card" instead of the system only using your on-board graphics.
Jul 01, 2017 | MSI P965 Platinum Motherboard
Will the micro-star ms-7255 run an intel pentium core-2 duo E7400 processor?
Yes i think....
Your motherboard supports cpu core2duo up to 1066mhz fsb.
E7400 got 1066mhz.
Maybe you have to update your bios version.
Dec 13, 2009 | MSI /Micro Star NX7800GTX-VT2D512E GeForce...
Gddr3 video cards
no the board doesn't support DDR3, you'll have to wait for the latest bios update so stick with DDR2 for the time being
Nov 22, 2008 | ASUS P5VD2-MX Motherboard
I need update for my vga card
it is the game defect. although u may upgrade the drivers from nivida's web site.
Nov 20, 2008 | MSI nVIDIA GeForce 6800 GT PCI-E 256MB...
Graphic card for gigabyte motherboard.
I just bought and installed a HIS Hightech H467QS512P Radeon HD 4670 512MB 128-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail. I pasted this from It is realy fast and is rated the best card for the money in CPU magizine this month. 80 bucks at Newegg with a free World Of Warcraft Game. PCI EXpress 2.0 is backward compatible with PCI Express 1.0 by the way.
Aug 10, 2008 | Intel Motherboard
Driver fr msi micro-star ms- 7255
This appears to be what you are looking for, however there seems to be three different models of that motherboard so be sure that you are looking at the correct model board.
May 30, 2008 | MSI /Micro Star NX7800GTX-VT2D512E GeForce...
GeForce 7600GS AGP 512MB card compatibility
it's hard to know,  it may be best to take your pc into a computer store and get them to test the compatability before you take it out of the store,  that way you can be sure that it works
Oct 13, 2007 | MSI nVidia GeForce 7600GS 256MB Dual DVI...
Computers & Internet Logo
43 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
