We have a 25 year old zenith console, pretty old.. but still functional.. we noticed that the tv turns blank to a green screen... no picture just green color shown on the screen, then it will go back to the picture sometimes.  Do you know what kind of problem is...
  • jessluvu Jan 20, 2009
    is this something anyone car repair, if so how would you do it?  And when you say cold solder do you mean affected by temperature, as it seems when the room gets warmer the tv is ok and the screen does not turn green... funny as it seems...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your described problem indicates that one of 3 color drive transistors (for the green) has developed either a cold solder (most likely) or an intermittent internal fault (leak). These transistors (or in some cases a single power pack module/IC) are normally found on a small squarish PCB (printed circuit board) at the very rear of the picture tube (CRT). At times, the green blank screen would also have diagonal fine lines or would appear to be overly bright.
In some rare instances, it could be the chroma section (least likely) or in worst case scenario the CRT (cathode ray tube) itself that is faulty (hope not).
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 18, 2009
  • Louie  Role
    Louie Role Jan 20, 2009
    Cold Solder would refer to a solder joint that was not "cooked enough", thew solder did not melt completely to join the transistor's leg and the board.
    This of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
    If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options and consider a replacement.
I have a 25" Zenith
You will need to replace 4 capacitors. Locations and values are C 3460 which is a 25 volt 220 Mf capacitor, CX3218 at 160 volts at 1 Mf (could be 2.2Mf), C3416 at 25 volts 100 Mf , and CX 3413 at 50 volts 22 Mf. In severe cases you would also replace the powerling regulator,(STR-53041) I don't think you need to in this case. Now the green spot you speak of may be the need to resolder the thermistor. I don't recall the exact location. It is a small disk located on the edge of the main board near the power board connection( Your 110 power cord to board). I also believe there is a glass fuse near by. This is a two legged disk that is silver. Take care when soldering this. If it does break you may replace this with an RCA part# 207768. And lastly, when replacing the board back into the TV, make sure you have a good connection to the CRT with the suction cup. It should be tight fitting with no air to escape! Thanks for asking and show a few hands of support!
Mar 27, 2011 | Zenith C25A24T TV
Zenith Rear Projection Model PVY5265RK
the problem you r facing is absolutely repairable but the charges will be heavy.
now its upon you to go for new or get it repaIRED.
i will suggest you to go to repair center and get it repaired as this problem is faced by many users and it is completely repaired.
Oct 24, 2008 | Zenith R56W36 56" Rear Projection...
I have an old 25" zenith, picture is great; but when I play a video with a lot of action scences . . . the picture refresh screen appears not to be able to keep up. Is there a solution to this problem...
The tv is definitely old, and this tv generally has a weak picture by now, creating red streaks pulling to the right. It may also have green or blue streaks...this is called frosting. Replace this set and see the difference!
Dec 19, 2009 | Televison & Video
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
TV Turns green and shuts off and less than 5 seconds.
In that TV its usually a bad picture tube. The green element of the tube is shorting.
Mar 13, 2009 | Zenith D32D51 32" TV
Zeneth 25"
the filter capacitor of 180 volts is weak or change value ,you need to change it .,the of that is 4.7/250volts or 10/250 volts.
Oct 12, 2008 | Zenith B25A11Z 25" TV
Dark picture, mostly red colors
if you set is over 4 yrs old the tube is at fault,you may try to adjust the screen settings.
Mar 27, 2008 | Zenith B25A76R 25" TV
Electricution sound w/ clicking noises and no picture
I am having the same exact issues wih the same TV and mine is only 2 years and 6 months old. Please let us know what is going on. Thank you.
Mar 07, 2007 | Zenith R40W46 40" Rear Projection...
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
