Question about Humidifiers
The Aprilaire is leaking around the casing attached to furnace
The aprilaire 224 humidifier is leaking around the black casing that attaches it to the furnace.
  • ward378 Feb 01, 2009
    anyone solve this problem? we don't know if we should take it apart or let it leak?
    Problem Solver:
  • 9 Answers
How old is the filter? Filters should be replaced every year. If its a new filter check to make sure the little hose is inside the hole at the tom of the filter.
Posted on Jan 19, 2009
Is Aprilaire 500M suppose to turn on when furnace motor turns on?
The humidifier should turn on and off with the blower motor of the Furnace. This can be done by wiring the the humidifier to the HUM terminal on the furnace control board and then stepping down the power with a transformer. If the humidifier has it's own tarnsformer then a current sensing relay can be used by attaching it to the blower motors common wire.
Jan 13, 2013 | Aprilaire Humidifiers
How to install an Aprilaire 400 humidifier
Here is a installation guide http://electronicaircleaners.com/database/documents/aprilaire_400_installation.pdf
Nov 09, 2011 | Aprilaire 400 Humidifier
Water running after heater shut off in humidifier
Hi check power at transformer / valve on water line could be stuck open clean valve out or transformer holding valve open
Dec 31, 2009 | Aprilaire 558 Humidifier
I replaced a clogged drain hose attached to my Aprilaire 600 humidifier. I then discovered no water was being supplied to the humidifier. The problem appeared to be a dangling solenoid wire that I had...
No, you need to attach one of the solenoid wires to the red wire and one to the white wire.
So, undo the wire nut with the three wire and hook one of the red or white wirtes to the wire nut with only one wire. Then you sould have a black wire and one of the other red or white wires under each wire nut.
Problem amy be that you now have burned out the transformer that runs your Humidifier. By hooking the red and white wires together you may have shorted that out and killed it.
If you humidifier does not work after hooking it back uo right then you will need to change the transformer.
Heatman101
Dec 28, 2009 | Aprilaire 600 Humidifier
New Aprilaire 700 - loud hi pitched whistle
You may be having problem with air scaping from the base of the hum. it will probably may have to put silicone around the base of the hum. to stop the air scaping.
Feb 05, 2009 | Aprilaire 700 Humidifier
Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Dec 24, 2008 | Aprilaire 550 Humidifier
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Leaking humidifier
Check for an obstructed drain line.
Feb 28, 2008 | Aprilaire 700 Humidifier
Aprilaire 110
Modle 110 has a relay in it see if it is stuck.Hope this helps
Nov 05, 2007 | Aprilaire 600 Humidifier
Humidifiers Logo
236 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
