Question about Hoover Vacuums
Hoover lynx won't charge
Go to use after charging and it dies
I know this question was quite awhile ago, however, I've had the same problem. I love the vacuum when it works. Bought one in October, returned it in March because the battery just stopped holding a charge. The store exchanged it for another one, and now, in May, this one has done the exact same thing . . . . wondering if anyone else is having this problem and what they did about it? Was considering switching to the Electrolux but not sure if that is any better product?
Posted on May 30, 2013
3 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: shark won't hold charge
How long are you letting it charge for? It's also possible the battery is defective, or there is a short in the vac.
Posted on May 27, 2012
small6363
  • 18424 Answers
SOURCE: Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Posted on Dec 22, 2012
    Can i wash the dirt cup on the hoover lynx?
    You have to wash the filter every time you empty the dirt cup
    Aug 16, 2014 | Hoover Vacuums
    Linx Hoover platinum won't turn on
    more than likely you'll have to order a new handle. Those machines are built in pieces so you just cant replace switch, motor, etc....
    Feb 13, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
    I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
    If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
    Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
    I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
    Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
    Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
    Irobot roomba 500
    If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
    Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
    Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
    Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
    If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
    Reinstall the battery.
    For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
    If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
    If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
    Jul 07, 2012 | iRobot Roomba 560 Robotic Vacuum
    Shark won't hold charge
    May 26, 2012 | Shark Vacuums
    I have a unit that is about 4 years old and appears to NOT hold a charge. I know to only charge for 3 hrs max but want to be sure my problem is the $75.00 battery before I purchase one. What is your...
    Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
    We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
    Shorting the battery like an Aircraft battery then re-charging won't fix it.
    Mar 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
    After charging,the vac cuts out after a minute or so. any help please?
    Jan 11, 2011 | Dyson DC16 Root 6 Bagless Handheld...
    Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
    Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
    Vacuums Logo
    53 people viewed this question
    Top Hoover Vacuums Experts
    Jim Parker
    Jim Parker
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
